How to bulk erase a 16f886 PIC
armondo58
PostPosted: Fri Nov 04, 2011 2:24 pm     Reply with quote
I had a working program, I made some small changes to the code, not fuses, when I now true to program the chip, I get verification errors. The compiler is 4.124 and CCS load 4.023. I suspect the code protect bit somehow got set and is giving me the errors. Thank in advance.
I used ICD-64 and ICD-40 both have same problem, Also tried on 2 working boards.
Thanks in advance.
armondo58
Solved
PostPosted: Sun Nov 06, 2011 3:41 pm     Reply with quote
If running under 5 volts and you can't erase and program, apply 5 volts and all seems to work normally.
