ADC voltage input follower
eabir
PostPosted: Thu Oct 27, 2011 11:41 pm     Reply with quote
I'm feeding PIC10F222 ADC input with increasing voltage.
What is the correct way to make sure, that the voltage is really increase in code ?
For example: input voltage in first sample is 1volts, two seconds later the input is 2volts, etc. but if after the two seconds the voltage is less then the first sample (here is 1volts) then do something..
I'm looking for elegant way to coding it.
PostPosted: Fri Oct 28, 2011 1:02 am     Reply with quote
Demo program for 10F222 A/D:
http://www.ccsinfo.com/forum/viewtopic.php?t=40263
