PIC18F46K22 to MRF89XA
Goto page Previous  1, 2
sawula
PostPosted: Fri Sep 23, 2011 12:27 am     Reply with quote
Hi scuba
Sawula-
MikroC is off-topic for the CCS compiler forum.
Find a MikroC forum or talk in a PM.
-- Forum Moderator
I am doing the same project with MRF89XA and PIC18F4550 using MIKROC Pro. And I am trying to convert your ccs code to Mikroc code. And I would like to know why are you using shif operations in registerset and registerRead functions ?
address = (address<<1);
      spi_write (address);
address = ((address<<1)|0x40);
        spi_write(address);
Can you please help me!
scuba
PostPosted: Fri Sep 23, 2011 9:34 am     Reply with quote
This code can be seen in radiodriver.c and mrf89xa.c which is the site of the microchip. I just adapted. To better understand i suggest the datasheet of mrf89xa. I also didn't understand well but i think is for data to be allocated at different addresses.
Greets
sawula
PostPosted: Tue Oct 11, 2011 1:47 am     Reply with quote
Hi scuba
How is progress of your project ? Were you able to communicate successfully?
scuba
PostPosted: Thu Oct 13, 2011 4:02 am     Reply with quote
Hi there, yes my project is done.
feint
PostPosted: Tue Jan 03, 2012 2:38 am     Reply with quote
hello scuba can you share the code
jeremy57350
PostPosted: Sat Feb 11, 2012 6:15 pm     Reply with quote
Hello, I'm currently on the same project as you. I sent an info temperature via this module. Can you share your code?
thank you
Itronica
PostPosted: Thu Feb 16, 2012 8:00 am     Reply with quote
Good morning, you can also have the file. H? Or the whole project? I am using the C18 with the library MIWI P2P but requires too many resources. thanks
Mariusz
Project files
PostPosted: Tue Nov 08, 2016 2:13 am     Reply with quote
Hi.
Can somebody add sample code for mrf89xam8a for SERVER and CLIENT (send and receive data) including header files please.
Thank you
Page 2 of 2
