eeprom write problem
ysaacb
PostPosted: Mon Jul 03, 2006 1:54 pm     Reply with quote
Hi everybody
1.-I wrote a small routine to write an array to a 24256 memory.
The first time the routine is called it works perfectly.
but the second time, the routine hangs up waiting for the write ack.
This is the code
writeExtMem(unsigned int16 address, char *data, unsigned int16 length) {
     #DEFINE PAGE_SIZE=64
   int8 i;
   int1 STATUS;
  if (length == 0)
    return;
  i2c_start();
  status=i2c_write(EEPROM_WRITE);
   while(status==1)
  status=i2c_write(address>>8);
   while (status==1)
  status=i2c_write(address);
   while (status==1)
  for (i=0; i < LENGTH; i++) // EEProm can only write 64 bytes at a time
   status=i2c_Write(*Data++);
   while (status==1)
    i2c_stop();
   i2c_start();
      while(status==1)
         i2c_start();
what is the diference between the slow and fast mod of the i2c?
Regards
Ysaac
Mark
PostPosted: Mon Jul 03, 2006 2:32 pm     Reply with quote
   while(status==1) ;
if i2c_write() returns 1, then you will sit here forever. You need to rethink this. I think that you intended to do something like:
  while (1)
    if (status !=1)
Your code is full of this. I would only check when you are addressing the eeprom. It doesn't make much sense any where else. If you get a failure any other place, then you need to repeat the entire process.
ysaacb
PostPosted: Tue Jul 04, 2006 5:15 am     Reply with quote
Dear Mark
I made the correction you suggest, but I still have the same problem: when the main program, call the this function the second time it hungs up trying to accses the EEprom i.e.:
this is the corrected one:
   int8 i;
   int1 STATUS;
  if (length == 0)
    return;
  i2c_start();
   while (1)
    if (status !=1)
    i2c_stop();
   i2c_start();
      while(status==1)
         i2c_start();
and this is the main program that read a text file an send it to the eeprom
#include <18f452.h>
#device icd=true
#fuses HS,NOWDT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=,bits=8)
#use i2c(master,sda=pin_C4,scl=pin_C3,force_HW)
#include <stdio.h>
#include <lcdd.c>
#include <string.h>
#include <I2C_24256_YB.h>
#define BUFFER_SIZE 80
#define PAGE_SIZE 64
#define LAST_CHAR '?'
char BUFFER[BUFFER_SIZE],BUFFER_OUT[BUFFER_SIZE];
char BUFFER_PAGE[PAGE_SIZE];
char char_out;
int1 ONLY_ONE;
int8 next_in,count_ch,LAST_NEXT_IN;
int16 EE_pointer;
#int_rda
void rx_serial_data()
   byte count_end,t;
   byte comp_last_4;
   char ch;
   ch=getc();
   buffer[next_in] =ch; // get the data(single character) from serial port
   count_ch=next_in;
void CLEAR_BUFFER_GSM()
   memset(buffer,0,(next_in+1));
   next_in=0;
void main ()
   boolean READY;
memset(buffer, 0, BUFFER_SIZE);
   ONLY_ONE=1;
   READY=TRUE;
   output_float(PIN_C4);
      output_float(PIN_C3);
      enable_interrupts(global);
   enable_interrupts(int_rda); // Enable 'receive data available' interrupt
      puts("ENVIE ARCHIVO");
   EE_pointer=0;
        while (BUFFER[count_ch]!=LAST_CHAR)
      if (next_in!=PAGE_SIZE)
         strncpy(BUFFER_PAGE,BUFFER,next_in);
         CLEAR_BUFFER_GSM();
           WriteExtMem(EE_pointer,BUFFER_PAGE,PAGE_SIZE);
         delay_ms(6);
            EE_pointer+=PAGE_SIZE;
      WriteExtMem(EE_pointer,BUFFER,next_in);
      delay_ms(6);
      EE_pointer=0;
      CLEAR_BUFFER_GSM();
      DO
         ReadExtMem(EE_pointer,&CHAR_OUT,ONLY_ONE);
         delay_ms(10);
         ++EE_pointer;
         putc(char_out);
      WHILE(char_out!=LAST_CHAR);
Regards Ysaac
wgalaugher
PostPosted: Sat Aug 20, 2011 4:21 pm     Reply with quote
Did this code ever get resolved; it looked like it was left in limbo.
I think this could, with a few mods, serve as the basis for what I am trying to do.
I'm trying to read a text file containing 132 four digit numbers (int16).
The code has to be buffered to handle the slow write of the eeprom.
Below is a sample of test data that would be read by the pic ie 18F2620 with a 24LC128
20
30
40
50
60
70
80
90
100
110
200
210
220
230
240
250
260
270
280
290
300
310
320
330
340
350
360
370
380
390
400
410
420
430
440
460
470
480
490
500
510
520
530
540
550
560
570
580
590
600
610
620
630
640
650
660
670
680
690
700
710
720
730
740
750
760
770
780
790
800
810
820
830
840
850
860
870
880
890
900
910
920
930
940
950
960
970
980
990
1000
1010
1020
1030
1040
1050
1060
1070
1080
1090
1100
1110
1120
1130
1140
1150
1160
1170
1180
1190
1200
1210
1220
1230
1240
1250
1260
1270
1280
1290
1300
1310
1320
1330
1340
1350
1360
1370
1380
1390
1400
1410
There is so much written that it is hard to pick the correct solution
dyeatman
PostPosted: Sat Aug 20, 2011 5:31 pm     Reply with quote
That's where FRAM comes in...
Google and Forum Search are some of your best tools
PostPosted: Sun Aug 21, 2011 4:56 am     Reply with quote
I don't understand the problem at hand. The only thing your application is doing is reading, but this is a problem because the write speed is slow? Doesn't make sense to me.
For a new hardware design I would recommend using the afore mentioned FRAM. All the advantages of EEPROM but as quick as the PIC can handle it.
wgalaugher
PostPosted: Sun Aug 21, 2011 9:06 am     Reply with quote
The use of Fram is terrific.
My first questions are:
Using Fram or eeprom
1. Can I use the code as is to read the text file and load the eeprom?
2. What if I don't have a page of data?
mutthunaveen
pull ups
PostPosted: Sun Aug 21, 2011 9:44 pm     Reply with quote
Hey did you use pullup resistors for the data and clock pin of SPI?? (10K to +5V)
