Left Shift operator
pilar
Left Shift operator
PostPosted: Wed Aug 03, 2011 9:50 am     Reply with quote
Hi, seem like a silly question but someone can tell me what this means?
data = 0xAB
data << 4;
Left Shift data 4 bits?
PostPosted: Wed Aug 03, 2011 12:49 pm     Reply with quote
data = 0xAB;
data << 4;
This won't do anything because it doesn't assign the result to an 'lvalue'.
This means it doesn't put the result into a variable.
Compile a test program with that code and look at the .LST file.
Notice the compiler doesn't even generate any code for the left-shift line:
.................... data = 0xAB;
0022:  MOVLW  AB
0024:  MOVWF  data
.................... data << 4;
If you put the assignment symbol after the operand, then you will get
the left-shifted result in 'data':
data = 0xAB;
data <<= 4;
Now look at the .LST file. It's actually doing something this time.
It's generating the left-shift code and it puts the result into 'data':
0022:  MOVLW  AB
0024:  MOVWF  data
.................... data <<= 4;
0026:  SWAPF  data,F
0028:  MOVLW  F0
002A:  ANDWF  data,F
