Watch speaks the hours
o cientista
PostPosted: Mon May 14, 2012 6:38 pm     Reply with quote
Good morning, friends!
I want to make a watch that speaks the hours with PIC and CCS C ISD25120 language, but one that is found in BASIC. I wanted to do in CCS C. because he wanted to adapt my usage. Can anyone turn this source code in CCS C? Thank you.
Agui is the link of the project and the source code below: http://www.freewebs.com/glafebre/relojparlante.htm
'PIC a utilizar
Device 16F871
'Frecuencia
XTAL 4
'declaracion del LCD
Declare LCD_TYPE 0
Declare LCD_DTPIN PORTC.4
Declare LCD_ENPIN PORTC.2
Declare LCD_RSPIN PORTC.3
Declare LCD_INTERFACE 4
Declare LCD_LINES 2
'teclado matricial
Declare KEYPAD_PORT PORTD
'---- DECLARACION DE LOS PINES DEL BUS I2C -------
SCL_PIN = PORTB.7
SDA_PIN = PORTB.6
'todos los puertos digitales
ALL_DIGITAL true
'variables
Dim tecla As Byte
Dim cont As Byte
Dim cont1 As Byte
Dim var1 As Byte
Dim segu As Byte
Dim minu As Byte
Dim hora As Byte
Dim minu1 As Byte
Dim minu2 As Byte
Dim diaS As Byte
Dim diaF As Byte
Dim mes As Byte
Dim anio As Byte
Dim eeprom As Byte
Dim control As Byte
Dim aux As Byte
Dim STRING1[10] As Byte
Dim horario As Bit
Symbol CE = PORTE.0
Symbol PD = PORTE.1
Symbol PR = PORTE.2
Symbol EOM = PORTC.0
TRISA = 0
DelayMS 500
cont=0
cont1=0
Cls
PORTA = 0
High CE
GoSub grabar_RTC
'Programa principal
inicio:
GoSub leer_RTC
tecla = InKey
Print At 1,12,DEC2 cont,"-"
Print At 1,15,DEC2 cont1,
Select Case tecla
Case 0: 'para grabar
GoSub antirebote 'antirebote de tecla
GoSub grabar
Case 1: 'para reproducir el msg seleccionado
GoSub reproducir
Case 2
cont1=cont1+1
Case 3
cont1=cont1-1
If cont1<0 Then
cont1=0
EndIf
Case 5
GoSub reproducir_HORA
Case 6
cont=cont+1
GoSub antirebote
Case 7
cont=cont-1
If cont<0 Then
cont=0
EndIf
GoSub antirebote
Case 8
GoSub antirebote
EndSelect
GoTo inicio
'Subrutinas
grabar:
PORTA=cont
High PD: DelayMS 10
Low PR:Low PD:High CE
Print At 2,1, "LISTO "
DelayMS 2000
Print At 2,1, "AHORA"
Low CE
DelayMS 1000
Print At 2,1, "FINALIZADO"
High CE
Return
reproducir:
PORTA=cont1
Print At 2,1, "REPRODUCIR"
High PR: Low PD: Low CE
While EOM <> 0 'buble para esperar el bajo en EOM para saber
Wend 'cuando ha finalizado el mensaje
High CE
Print At 2,1, " "
Return
antirebote:
While tecla<>16 'antirebote
tecla=InKey
Wend
Return
grabar_RTC:
BusOut %11010000,0,[$00] 'segundos
DelayMS 50
BusOut %11010000,1,[$59] 'mitutos
DelayMS 50
BusOut %11010000,2,[$10] 'horas
DelayMS 50
BusOut %11010000,3,[$4] 'dia de la semana
DelayMS 50
BusOut %11010000,4,[$19] 'dia del mes
DelayMS 50
BusOut %11010000,5,[$07] 'mes
DelayMS 50
BusOut %11010000,6,[$06] 'año
DelayMS 50
BusOut %11010000,7,[$10] 'frec 1hz
DelayMS 50
Return
leer_RTC:
BusIn %11010000,0,[segu]
BusIn %11010000,1,[minu]
BusIn %11010000,2,[hora]
BusIn %11010000,3,[diaS]
BusIn %11010000,4,[diaF]
BusIn %11010000,5,[mes]
BusIn %11010000,6,[anio]
Print At 1,1, HEX2 hora,":",HEX2 minu,":",HEX2 segu," "
If diaS=$1 Then Print At 2,1, "Dom."
If diaS=$2 Then Print At 2,1, "Lun."
If diaS=$3 Then Print At 2,1, "Mar."
If diaS=$4 Then Print At 2,1, "Mie."
If diaS=$5 Then Print At 2,1, "Jue."
If diaS=$6 Then Print At 2,1, "Vie."
If diaS=$7 Then Print At 2,1, "Sab."
Print At 2,6,HEX2 diaF,"/"
Print At 2,11," /20",HEX2 anio
If mes=$1 Then Print At 2,9, "Ene"
If mes=$2 Then Print At 2,9, "Feb"
If mes=$3 Then Print At 2,9, "Mar"
If mes=$4 Then Print At 2,9, "Abr"
If mes=$5 Then Print At 2,9, "May"
If mes=$6 Then Print At 2,9, "Jun"
If mes=$7 Then Print At 2,9, "Jul"
If mes=$8 Then Print At 2,9, "Ago"
If mes=$9 Then Print At 2,9, "Sep"
If mes=$10 Then Print At 2,9, "Oct"
If mes=$11 Then Print At 2,9, "Nov"
If mes=$12 Then Print At 2,9, "Dic"
Return
reproducir_HORA:
GoSub leer_RTC
'--------------- son
cont1=21
GoSub reproducir
DelayMS 100
'--------------- las
cont1=22
GoSub reproducir
DelayMS 100
'--------------- HORAS
If hora>=10 And hora<32 Then
hora=hora-6
EndIf
If hora>=32 And hora<48 Then '20
hora=hora-12
EndIf
If hora>12 Then
hora=hora-12
horario=1
Else
horario=0
EndIf
cont1=hora
GoSub reproducir
DelayMS 100
'--------------- AM/PM
If horario=1 Then
cont1=24
Else
cont1=23
EndIf
GoSub reproducir
DelayMS 100
'--------------- Y
cont1=20
GoSub reproducir
DelayMS 100
'--------------- MINUTOS
If minu>=10 And minu<32 Then '10
minu=minu-6
EndIf
If minu>=32 And minu<48 Then '20
minu=minu-12
EndIf
If minu>=48 And minu<64 Then '30
minu=minu-18
EndIf
If minu>=64 And minu<80 Then '40
minu=minu-24
EndIf
If minu>=80 And minu<96 Then '50
minu=minu-30
EndIf
Select Case minu
Case 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
cont1=minu
GoSub reproducir
Case Else
minu2=Dig minu, 1
minu2=minu2*10
cont1=minu2
Select Case cont1
Case 20
cont1=16
Case 30
cont1=17
Case 40
cont1=18
Case 50
cont1=19
EndSelect
GoSub reproducir
DelayMS 100
If minu<>20 And minu<>30 And minu<>40 And minu<>50 Then
cont1=20
GoSub reproducir
DelayMS 100
minu1=Dig minu, 0
cont1=minu1
GoSub reproducir
EndIf
EndSelect
DelayMS 100
'--------------- MINUTOS (PALABRA)
cont1=25
GoSub reproducir
Return
End
Mike Walne
PostPosted: Sat May 19, 2012 3:27 am     Reply with quote
You've had no response after several days.
It's probably because there's too much effort required for no return.
The whole thing looks to be fairly standard.
I suggest you have a go yourself, and come back when you're stuck.
Mike
bkamen
PostPosted: Sun May 20, 2012 5:43 pm     Reply with quote
yea....
I might also offer that it might be because this forum is intended to help people learning to program PIC's -- not do the work for them.
Cheers,
-ben
