dsPIC33FJ I/O ports problems [solved]
mabd
PostPosted: Wed Jul 13, 2011 5:25 am     Reply with quote
I'm using a dsPIC33FJ128GP706 and I use several pins like outputs. Pins C15, G6, G7 and G8 not works ok.
I configure them with TRIS C and G these pins like outputs.
I try to put high with output high and writing directly in registers PORTC, LATC, PORTG and LATG but is not possible.
I have 4.120 version.
With 4.084 version pin C15 works ok but port G no.
mabd
Solved
PostPosted: Wed Jul 13, 2011 7:11 am     Reply with quote
I've solved the problem.
Pin C15 not works because Fuses are wrong.
Pins G6-7-8 not works because with CCS SPI functions the SPI can't disable it. It's necessary to modify spi registers directly
Sorry
