GPRMC GPS message decode
PICoHolic
PostPosted: Tue Jul 12, 2011 5:44 am     Reply with quote
#include <string.h>
#include <stdlib.h>
typedef struct _DateTimeInfo
   int8 Day;
   int8 Month;
   int8 Year;
   int8 Hour;
   int8 Minute;
   int8 Second;
} DateTimeInfo;
typedef struct _GPRMCInfo
   char Valid;
   DateTimeInfo DT;
   float Latitude;
   char N_S;
   float Longitude;
   char E_W;
   float Speed;
} GPRMCInfo;
//copy string (pos n to pos m) from s2 to s1
char* StrnmCpy(char *s1, char *s2, size_t n, size_t m)
   int8 i;
   char *s;
   for (s=s1, i=n, s2+=n; i<=m; i++)
      *s++ = *s2++;
   *s = '\0';
   return s1;
// find c in s starting from pos st
int8 StrFnd(char *s, char c, size_t st)
   int8 l;
   for (l=st, s+=st ; *s != '\0' ; l++, s++)
      if (*s == c)
         return l;
   return -1;
void GPRMC_decode(char *GPRMCStr, GPRMCInfo *RMCInfo)
   int8 p1, p2;
   char TempStr[16];
   p1 = StrFnd(GPRMCStr, ',', 0);      //find first comma
   if (p1 == 6)
      //check for valid packet:
      if ( (StrFnd(GPRMCStr, 'A', p1+1) == 18) && (GPRMCStr[0]=='$')) //valid?
         RMCInfo->Valid = 'A';
         //Get time
         p2 = StrFnd(GPRMCStr, ',', p1+1);   //find next comma
         RMCInfo->DT.Hour = atoi(StrnmCpy(TempStr, GPRMCStr, p1+1, p1+2));   //hour
         RMCInfo->DT.Minute = atoi(StrnmCpy(TempStr, GPRMCStr, p1+3, p1+4)); //min
         RMCInfo->DT.Second = atoi(StrnmCpy(TempStr, GPRMCStr, p1+5, p1+6)); //sec
         //Get latitude & direction
         p1 = StrFnd(GPRMCStr, ',', p2+1);   //find next comma
         RMCInfo->Latitude = atof(StrnmCpy(TempStr, GPRMCStr, p1+1, p2-1));
         RMCInfo->N_S = GPRMCStr[p2+1];
         //Get longitude & direction
         RMCInfo->Longitude = atof(StrnmCpy(TempStr, GPRMCStr, p1+1, p2-1));
         RMCInfo->E_W = GPRMCStr[p2+1];
         //Get speed
         RMCInfo->Speed = atof(StrnmCpy(TempStr, GPRMCStr, p1+1, p2-1));
         //Get date
         RMCInfo->DT.Day = atoi(StrnmCpy(TempStr, GPRMCStr, p1+1, p1+2));  //dd
         RMCInfo->DT.Month = atoi(StrnmCpy(TempStr, GPRMCStr, p1+3, p1+4));//mm
         RMCInfo->DT.year = atoi(StrnmCpy(TempStr, GPRMCStr, p1+5, p1+6)); //yy
      else                                //not valid
         RMCInfo->Valid = 'V';
drx2k
example
PostPosted: Sun Jun 03, 2012 11:59 pm     Reply with quote
how to use this code?
PICoHolic
Usage
PostPosted: Thu Aug 02, 2012 5:27 am     Reply with quote
Interrupt routine for UART:
char GPSData[128];
unsigned int8 GPSDataPtr=0;
char c;
int8 GPSDataReady = FALSE;
int8 GPSmsgCount = 0;
#INT_RDA
void RDA_isr(void)
   c = getc();
   switch (c)
      case '$':
         GPSDataPtr = 0;
      case '\n':
         GPSDataReady = TRUE;
   GPSData[GPSDataPtr++ & 0x7F] = c;
Somewhere in main():
if (GPSDataReady)
         GPRMC_decode(GPSData, &MyGPRMCInfo);
         if (MyGPRMCInfo.Valid == 'A')
               #ifdef DEBUG_MODE
                     printf("\n\rTime: %d:%d:%d\n\r", MyGPRMCInfo.DT.Hour, MyGPRMCInfo.DT.Minute, MyGPRMCInfo.DT.Second);
                     printf("Date: %d/%d/%d\n\r", MyGPRMCInfo.DT.Day, MyGPRMCInfo.DT.Month, MyGPRMCInfo.DT.Year);
                     printf("Latitude: %f %c\n\r", MyGPRMCInfo.Latitude, MyGPRMCInfo.N_S);
                     printf("Longitude: %f %c\n\r", MyGPRMCInfo.Longitude, MyGPRMCInfo.E_W);
                     printf("Speed: %f knots\n\r", MyGPRMCInfo.Speed);
                     printf("Data saved!\n\r");
lan ahmad
PostPosted: Sun Oct 07, 2012 11:23 am     Reply with quote
Undefined Indentifier MyGPRMCInfo?
what is MyGPRMCInfo?
PICoHolic
PostPosted: Sun Oct 07, 2012 12:55 pm     Reply with quote
It's a variable of type GPRMCInfo (the structure above)
GPRMCInfo MyGPRMCInfo;
lan ahmad
PostPosted: Fri Dec 14, 2012 10:58 am     Reply with quote
how i can define it?where?
PICoHolic
PostPosted: Sat Dec 15, 2012 3:37 am     Reply with quote
It's already defined above!!
Just declare it before you use it!
Jhonny
PostPosted: Sun Feb 09, 2014 8:01 am     Reply with quote
Dear Picoholic! Please describe for me exactly where and how to declare this "MyGPRMCInfo." The source would be great, but unfortunately, the compiler writes error:
"Undefined identifier MyGPRMCInfo" - Because of this, unfortunately can not use the code. (Please understand, I'm a beginner!) Thank you very much for your help! Embarassed
PICoHolic
PostPosted: Sun Feb 09, 2014 12:52 pm     Reply with quote
I have already answered that. Scroll up.
PostPosted: Sun Feb 09, 2014 1:31 pm     Reply with quote
He wants to know where to put the declaration. Since the demonstration
code above is said to be "somewhere in main", then he can put the
declaration at the start of main(). That's all he wants to know.
Jhonny
PostPosted: Mon Feb 10, 2014 7:55 am     Reply with quote
Dear PCM programmer! That's right, you say! That's exactly what I wanted. Thank you very much for your help and for PICoHolic! Wink
PICoHolic
PostPosted: Mon Feb 10, 2014 9:09 am     Reply with quote
Dear Jhonny, glad it works.
PS: in order to write a program in C for a microcontroller, a minimum knowledge in C language is required. Declaring a variable before using it is an extremely basic thing to know. Am I mistaken?
After all CCS forum is not a C language forum, it's a microcontroller programming forum using CCS C compiler. C language should be a prerequisite.
Cheers!
JAM2014
PostPosted: Fri Jun 08, 2018 10:40 am     Reply with quote
Hi All,
Here is a modified version of PICoHolic's NMEA parsing routines that adds the NMEA checksum to the GPRMC structure.
#include <string.h>
#include <stdlib.h>
   int8 Day;
   int8 Month;
   int8 Year;
   int8 Hour;
   int8 Minute;
   int8 Second;
} DateTimeInfo;
   char Valid;
   DateTimeInfo DT;
   float Latitude;
   char N_S;
   float Longitude;
   char E_W;
   float Speed;
   int8 Checksum;
} GPRMCInfo;
   int8 i;
   char *s;
      *s++ = *s2++;
   *s = '\0';
   return s1;
   int8 l;
      if (*s == c)
         return l;
   return -1;
   int8 p1, p2;
   int8 TempVal;
   char TempStr[16];
   if (p1 == 6)
         //Get time
         //Get speed
         //Get date
       //Get checksum
       p1 = StrFnd(GPRMCStr, '*', 0);   //find first asterisk
       TempStr[0]='0';
       TempStr[1]='x';
       StrnmCpy(TempStr+2, GPRMCStr, p1+1, p1+2);
       RMCInfo->Checksum = atoi(TempStr);
      else                                //not valid
Jack
