gpsmikey
| 16F1827 software uart problem ... [SOLVED] |
Posted: Mon Jul 11, 2011 12:54 pm |
Greetings all - I'm running into a problem getting the software uart function to work correctly with a PIC16f1827 - compiler 4.114.
Simple little routine that sets up the PWM (which works), flashes a LED (which works) and sends a message out on pin b7 (which does not work). Don't see any activity on B7, but I do see a burst of data on B2. I need it on B7 for the UART Tool in the pickit2 to see it. Here is the program I have that should work (same format as I used in a 18F14k22 processor). Something obvious I am missing or is this a bug in the compiler ?
#include <main.h>
#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B6, ERRORS, PARITY=N, \
BITS=8, STREAM=MIKEYMON)
// config ccp1 for pwm using timer 2
output_low(PIN_B3); // Set CCP1 output low
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_16, 255, 1); // Setup for 1.95khz
set_pwm1_duty(128); // 50% duty cycle
//Example blinking LED program
while(true){
output_low(LED0);
delay_ms(DELAY);
output_high(LED0);
delay_ms(DELAY);
fprintf(MIKEYMON,"test message from mikey\r\n");
_________________ mikey
gpsmikey
Posted: Mon Jul 11, 2011 1:07 pm |
It was a compiler bug - updated to version 4.118 that I had downloaded within my 60 days, and same code now works as expected :-)
mikey _________________ mikey
