Internal Error when using printf and lcd_putc
MegatroniC
View user's profile Send private message ICQ Number
PostPosted: Thu Jun 30, 2011 10:20 am     Reply with quote
Please for help,
in this subroutine I get the following error when compiling:
Error 44 "main.c" Line 269(1,1), internal error - Contact CCS LABEL SCR=1677
LCD Driver http://www.ccsinfo.com/forum/viewtopic.php?t=24661&highlight=lcd
SWITCHES - http://www.ccsinfo.com/forum/viewtopic.php?t=22145&highlight=button
subroutine
void main_menu(void)
 int1 exit=0;
 int8 menu_marker=0;
 lcd_gotoxy(1,1);
 lcd_putc("Setting \n");
 lcd_putc(" times  ");
 delay_ms(1500);
 lcd_putc("\f");
 do{
    switch(menu_marker){
      case 0: lcd_gotoxy(1,1);
              lcd_putc("Time 1i\n");
              printf(lcd_putc, "%3d sec", time1);        //line 269
              delay_ms(30);
              while(!scroll_click && !set_click);
              if(set_click) {incrdecr1(time1,59,1,1,2,2); write_eeprom(0,time1); menu_marker=0;}
               else if(scroll_click) menu_marker=1;
     case 1: lcd_gotoxy(1,1);
             lcd_putc("Time 1p\n");
             printf(lcd_putc, "%3d sec", time1p);
             delay_ms(30);
             if(set_click) {incrdecr1(time1p,59,1,1,2,2); write_eeprom(1,time1p); menu_marker=1;}
              else if(scroll_click) menu_marker=2;
     case 2: lcd_gotoxy(1,1);
             lcd_putc("Time 2i\n");
             printf(lcd_putc, "%3d sec", time2);
             delay_ms(30);
             if(set_click) {incrdecr1(time2,59,1,1,2,2); write_eeprom(2,time2); menu_marker=2;}
              else if(scroll_click) menu_marker=3;
     case 3: lcd_gotoxy(1,1);
             lcd_putc("Time 2p\n");
             printf(lcd_putc, "%3d sec", time2p);
             delay_ms(30);
             if(set_click) {incrdecr1(time2p,59,1,1,2,2); write_eeprom(3,time2p); menu_marker=3;}
              else if(scroll_click) menu_marker=4;
     case 4: lcd_gotoxy(1,1);
             lcd_putc("Time 3i\n");
             printf(lcd_putc, "%3d min", time3);
             delay_ms(30);
             if(set_click) {incrdecr1(time3,59,1,1,2,2); write_eeprom(4,time3); menu_marker=4;}
              else if(scroll_click) menu_marker=5;
    if(scroll_click && menu_marker==5)
     {menu_marker=0;
      lcd_gotoxy(1,1);
      lcd_putc(" Exit? \n");
      lcd_putc("push set");
      delay_ms(30);
      if(set_click) exit=1;
      else exit=0;
   }While(!exit);
    lcd_gotoxy(1,1);
    lcd_putc("  Save  \n");
    lcd_putc("settings");
    delay_ms(2000);
    read_store_value_and_start();
The error appears on lines with lcd_putc and printf, I think it gets in conflict with lcd_gotoxy(1,1) and \n, but it exists and where the use lcd_goto(1,2) instead of \n.
PostPosted: Thu Jun 30, 2011 11:30 am     Reply with quote
Post your PIC and #fuses and #use delay(), and your compiler version
so a test program can be made.
MegatroniC
PostPosted: Thu Jun 30, 2011 11:54 am     Reply with quote
Compiler version 4.114
#include <18F2520.h>
#device adc=8
#OPT 11                         //Optimization level
#FUSES WDT8192                  //Watch Dog Timer 30s
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES PROTECT                  //Code protected from reads
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES PUT                      //Power Up Timer
#FUSES NOSTVREN                 //Stack full/underflow will not cause reset
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOLPT1OSC                //Timer1 configured for higher power operation
#FUSES MCLR                     //Master Clear pin enabled
#use delay(clock=4MHz)
Not for the first time using such a short menu, but my first time going to an error. Smile
PostPosted: Thu Jun 30, 2011 12:50 pm     Reply with quote
I put together a test program and I am getting the Internal Error message.
I'll look at it and see if I can find the problem.
MegatroniC
PostPosted: Thu Jun 30, 2011 1:32 pm     Reply with quote
Thank you very much for your attention.
Still learning and I will be interested to know if the problem is me.
PostPosted: Thu Jun 30, 2011 1:48 pm     Reply with quote
#device adc=8
// #OPT 11 //Optimization level
BUILD SUCCEEDED: Thu Jun 30 12:49:43 2011
The error message disappears if I comment out the #opt 11, which is
sort of to be expected. My basic rule is "don't push the compiler".
MegatroniC
PostPosted: Thu Jun 30, 2011 3:02 pm     Reply with quote
So I wrote the code that is not efficient enough to be optimized ... Is this supposed to mean?
Thanks for the advice PCM programmer!
PostPosted: Thu Jun 30, 2011 3:11 pm     Reply with quote
NO, it means what he said. Don't push the limits of the compiler". If you
want that kind of optimization go buy the $1800 compiler.
Any compiler is going to have problems if you try to push the amount of
optimization to the extreme. Unless you are a professional programmer
writing critical code you very likely don't need it anyway. If you are a
student you certainly do not. If you want more optimization then code in
assembly..
My apologies for jumping in PCM, I just couldn't let this lie...
MegatroniC
PostPosted: Thu Jun 30, 2011 3:33 pm     Reply with quote
I am not a student anymore. Smile
I am interested in programming, and teach myself as far as I can.
Thank you all.
