IEE FLIP VFD 1x16 Screen driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
Gabriel
PostPosted: Tue Aug 19, 2014 11:32 am     Reply with quote
Hi All,
This is a little serial driver for a VFD screen I had.
You can see the screen in action here:
https://hackaday.io/project/2391-VFD-Shenanigans
It just sees the incoming characters and if there is a comma or period it substitutes the previous character with the corresponding character value that includes a comma.
In other words it allows you to display data like:
[A, B, C. D.]
Instead of
[A , B , C . D .]
Without this "driver" the commas and periods would use an entire character space on their own.
Test Program:
#include <16f886.h>
#device adc=8
#device *=16
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NODEBUG
#include "FLIP_VFD_1x16.c"
      putc(EOL_MODE3);      // set screen wraping mode
      //Test escape characters
      Printf(Subset,"\n\r---- \' \" \\ ----");
      delay_ms(3000);
      //Test Symbols with periods & commas
      Printf(Subset,"\n\r#,. ,?,.%,$.*,/.+.-,}{_.(,");
      delay_ms(3000);
      //Test Letters with periods & commas
      Printf(Subset,"\n\ra,b,c,x,y,z,@.A.B.C.X.Y.Z.");
      delay_ms(3000);
Driver:
#define COMM_PIN    PIN_B0   // Serial pin to talk to VFD
#define CLR_DISPLAY 0x0A    // AKA: Line Feed - '\n'
#define CR_RETURN   0x0D    // AKA: Return '\r'
#define BACK_SPACE    0x08
#define FWD_SPACE    0x09
#define BLINK      0x0B
#define NO_BLINK    0x0C
#define VIEW_CURSOR   0x0F
#define HIDE_CURSOR 0x0E
#define EOL_MODE1    0x11   // Default - Automatic CR
#define EOL_MODE2    0x12   // Overwrite Rightmost char
#define EOL_MODE3    0x13   // Scroll right to left
#use rs232(baud=1200, xmit=COMM_PIN,STOP=2, ERRORS) // Software Serial
char Previous_Char;         // Global Var
void Subset(char);         // Fuction Declaration
void Subset(char Next_Char)
   if((Next_Char=='.')&&(Previous_Char<0x80)&&(Previous_Char!='.'))
      putc(BACK_SPACE);
         if((Previous_Char>0x60)&&(Previous_Char<0x7B))
            Previous_Char-=0x20;
      Next_Char=Previous_Char|0x80;
   if((Next_Char==',')&&(Previous_Char>0x3F)&&(Previous_Char!=','))
      putc(BACK_SPACE);
      Next_Char=Previous_Char|0xA0;
   if((Next_Char==',')&&(Previous_Char<0x40)&&(Previous_Char!=','))
      putc(BACK_SPACE);
      Next_Char=Previous_Char+0x60;
   putc(Next_Char);
   Previous_Char=Next_Char;
G.
CCS PCM 5.078 & CCS PCH 5.093
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
