16f876 and lcd
adalucio
16f876 and lcd
PostPosted: Mon May 09, 2011 12:11 pm     Reply with quote
Hi all
I'm trying to use a (working) lcd (20x2) with a 16f876. I have a 20Mhz quartz.
I see only the first line with all square.
DB4 - RA2
DB5 - RA0
DB6 - RA1
DB7 - RA4
RS - RB6
RW - RA3
E - RB7
main.c
#include <main.h>
#include "flex_lcd_16x1.c"
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   lcd_init();
   delay_ms(600);
   printf(lcd_putc, "\fABCDEFGHIJKLMNOPQRST");
   printf(lcd_putc, "\nabcdefghijklmnopqrst");
   delay_ms(2000);
      output_high(PIN_B0);
      output_low(PIN_B0);
      printf(lcd_putc, "Test");
main.h
#include <16F876.h>
#FUSES HS                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES PUT                      //Power Up Timer
#define LCD_DB4   PIN_A2
#define LCD_DB5   PIN_A0
#define LCD_DB6   PIN_A1
#define LCD_DB7   PIN_A4
#define LCD_RS    PIN_B6
#define LCD_RW    PIN_A3
#define LCD_E     PIN_B7
PostPosted: Mon May 09, 2011 12:17 pm     Reply with quote
DB4 - RA2
DB5 - RA0
DB6 - RA1
DB7 - RA4
RS - RB6
RW - RA3
E - RB7
Pin A4 is open-drain on this PIC. It needs an external 4.7K pull-up
resistor on that pin, to operate as an output pin. The LCD has a pull-up
on the DB7 pin, but it's very weak. You should add the external 4.7K
pull-up to it.
Also, you're using pins B6 and B7 for the lcd. Those are the programmer
and debugger pins (for ICD2, ICD3, PicKit, ICD-U40, etc.). The lcd
won't run if the ICD is connected to the board. It's better if you use two
other pins for the lcd.
Also, you are using the wrong Flex driver. You have a 2-line LCD.
I think the 16x2 Flex driver would work OK for your LCD:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
adalucio
PostPosted: Tue May 10, 2011 2:11 am     Reply with quote
Thanks it worked
Very Happy Very Happy Very Happy
