glcd 192x64 question
albe01
PostPosted: Sat Apr 09, 2011 6:14 am     Reply with quote
Hello to everyone... I'd like use a glcd 192x64 KS0108 in my project, but in ccs this driver is not available... possible solutions to solve this problem?
best regards
http://www.ciahk.net/upload/docs/HY-19264B.pdf
PostPosted: Sat Apr 09, 2011 8:20 am     Reply with quote
Hopefully you'll find more info than just that one data sheet
First, I'd 'google' to find more info,you're NOT the first one whose needed a driver for this display. While others may have used other ucomputers and languages, you should be able to 'follow' the way it's done.
I'd printout another GLCD driver and it's GLCD datasheet then compare the pin functions as most are very similar.
Once you have it properly connected and get 'dots', copy a driver, rename it, then modify it for the specs of your GLCD.
Not having your display, I can't write and test the code, but it should only take a pleasant afternoon to get it working.
PostPosted: Sat Apr 09, 2011 2:24 pm     Reply with quote
Search the forum for KS0108* and you will find posts on this topic:
http://www.ccsinfo.com/forum/viewtopic.php?t=44761
