david91184
| I2C SET MULTI_MASTER |
Posted: Sun Apr 10, 2011 2:39 am |
I have to do is to use four dsPIC33 the value to an EEPROM using I2C transmission problems, I now hit me that the signal will be searched on the site also tried to sample a lot of information occur collision would like to ask the network signal Of you help me
#include <33FJ64MC802.h>
#fuses HS,NOWDT,NODEBUG,NOWRTSS,NOPROTECT ,PR_PLL,ALTI2C
#use delay (clock=80M, crystal=10M)
#pin_select U1TX = PIN_B4
#pin_select U1RX = PIN_B5
#use rs232(UART1,baud=115200,parity=N,bits=8)
#bit U1STA_UTXEN = 0x223.2
#use i2c(multi_master, scl=PIN_B8, sda=PIN_B9)
char cmd;
int flag=0;
int16 data_a0=0,data_a1=0,data_read=0,x=0,POS1CNT=0,y=0;
/*void init_ext_eeprom()
output_float(PIN_B8);
output_float(PIN_B9);
void write()
int status;
int state;
do
output_high(pin_a0);
i2c_start();
state=i2c_write(0xa0);
if(state==0)
if(y!=POS1CNT)
i2c_start();
i2c_write(0xa0);
i2c_write(0x01>>8);
i2c_write(0x01);
i2c_write(POS1CNT>>8);
i2c_stop();
i2c_start();
status=i2c_write(0xa0);
while(status==1)
i2c_start();
i2c_stop();
i2c_start();
i2c_write(0xa0);
i2c_write(0x02>>8);
i2c_write(0x02);
i2c_write(POS1CNT);
i2c_stop();
i2c_start();
while(status==1)
i2c_start();
i2c_stop();
y=POS1CNT;
if(state==1) i2c_stop();
output_low(pin_a0);
}while(state!=0);
int read1()
int state;
do
i2c_start();
if(state==0)
i2c_start();
i2c_write(0xa0);
i2c_write(0x01>>8);
i2c_write(0x01);
i2c_start();
i2c_write(0xa1);
data_a0=i2c_read(0);
i2c_stop();
i2c_start();
i2c_write(0xa0);
i2c_write(0x02>>8);
i2c_write(0x02);
i2c_start();
i2c_write(0xa1);
data_a1=i2c_read(0);
i2c_stop();
data_read=(data_a0<<8)+data_a1;
}while(state!=0);
return data_read;
#int_RDA
void RDA_isr()
cmd = getchar();
switch(cmd)
case 'S':
U1STA_UTXEN = 1;
case 'E':
U1STA_UTXEN = 0;
case 'Q':
flag=1;
case 'W':
flag=0;
#INT_TIMER1
void TIMER1_isr( )
set_timer1(65535-125);
x++;
if(x == 100)
x=0;
write();
void main (void)
enable_interrupts(INT_RDA);
enable_interrupts (INTR_GLOBAL);
setup_timer1(TMR_INTERNAL|TMR_DIV_BY_8);
U1STA_UTXEN = 0;
//init_ext_eeprom();
POS1CNT=read1();
while (1)
output_high(pin_b15);
if(flag==1)
printf("\r\nPOS1CNT:%d",POS1CNT++);
