cerr
Joined: 10 Feb 2011 Posts: 241 Location: Vancouver, BC
Timer problem |
Posted: Mon Mar 14, 2011 3:10 pm |
Hi There,
I've been having a problem with my timers and several people have told me i should sumarize my problem in a sample app. That's what I've done now but even my sample app has 182 lines and I'm hesitant to post that here. A summary, I have three frequency timers that will kick in every xms, e.g. 50Hz . When that kicks in, it sets a port and starts a "pulse timer" that will kick in after "pulse length" (~200-500uS) to reset the pin again.
And because i need the possibility to offset them to each other, I defined one freq timer as the master timer and the two thers can be offset to that. The offset can be +/- XuS. I would start the 3 frequency timers with delays in between each other to satisfy the offsets and then use the same count variable for all to satisfy the frequency (which is for now for all the same but will be able to be different in the next version of the product).
So far so good in my head but something doesn't work correctly.
There's always an offset between the timers. I don't get them lined up properly. My offset theory doesn't seem to work... :(
Instead of jamming up this forum, the source code can be downloaded from:here - Would be awesome if someone had a little time and could help me!
Thank you in advance! |
cerr
Posted: Wed Mar 16, 2011 10:10 am |
No ideas? Or no time looking at it at all, maybe?  |
ALPL
Posted: Thu Mar 17, 2011 7:51 am |
I don“t know your code but did you consider the time your function calls within the ISR(s) take when they are executed? You need to adjust for this time-delay. |
Geps
Posted: Thu Mar 17, 2011 7:57 am |
cerr wrote: | No ideas? Or no time looking at it at all, maybe?  |
I don't think anyone will take the risk downloading from that site. Quote it here....the forum is here to get clogged up with code  |
cerr
Posted: Fri Mar 18, 2011 10:03 am |
Uh okay, if you think so, here it is:
Code: | #include <18F87K22.h>
#device ICD=TRUE
#device adc=16
#FUSES HSM //Hi-Speed crystal oscillator
#FUSES NOPLLEN //No PLL enabled
#FUSES BBSIZ1K //1K words Boot Block size
#use delay(clock=10000000)
#define CALC 625000 //calculation constant for timer calculations ((10000000/4)/4)
#define FREQMHZ 10
#define SET_LPRTMR set_Timer1
#define SET_OVRTMR set_timer3
#define SET_SYNCTMR set_timer5
#define MCU1_SYNC PIN_D1
#define LL_LPR PIN_D2
#define LL_OVR PIN_D3
unsigned int32 timval=0;
int main (void){
setup_timer_1(T1_DISABLED ); // Setup timer for LPR LL pulse
setup_timer_3(T3_DISABLED ); // Setup timer for OVR LL pulse
setup_timer_5(T5_DISABLED ); // Setup timer for SYNC pulse
float period=0;
float fixval=0;
int1 config=0;
unsigned int8 LPRval=0;
unsigned int8 OVRval=0;
unsigned int8 SYNCval=0;
int16 LPRwdt=500;
int16 OVRwdt=500;
int16 SYNCwdt=500;
SIGNED int16 LPRoff=0;
SIGNED int16 OVRoff=0;
while (true){
if (!config){
int8 Freq=50;
period=1/(float)Freq;
timval=65560-(CALC*(1/(float)Freq));
/*** calculate timer values for pulse widths ***/
fixval=1/((float)FREQMHZ/4/16);
LPRval=LPRwdt/fixval;
OVRval=OVRwdt/fixval;
SYNCval=SYNCwdt/fixval;
setup_timer_2(T2_DIV_BY_16, LPRval, 1); // Setup timer for LPR LL pulse
setup_timer_4(T4_DIV_BY_16, OVRval, 1); // Setup timer for OVR LL pulse
setup_timer_6(T6_DIV_BY_16, SYNCval, 1); // Setup timer for SYNC pulse
/*** start "frequency timers" in correct order ***/
if((LPRoff<OVRoff)){
if (LPRoff<0){
if (OVRoff<0){
// LPR, OVR, SYNC
SET_LPRTMR(timval);
delay_us((LPRoff-OVRoff)*-1);
SET_OVRTMR(timval);
delay_us(OVRoff*-1);
SET_SYNCTMR(timval);
} else {
// LPR, SYNC, OVR
SET_LPRTMR(timval);
delay_us(LPRoff*-1);
delay_us(OVRoff);
SET_OVRTMR(timval);
} else {
// SYNC, LPR, OVR
delay_us(LPRoff);
SET_LPRTMR(timval);
delay_us(OVRoff-LPRoff);
SET_OVRTMR(timval);
} else if (OVRoff<LPRoff) {
if (OVRoff<0){
if (LPRoff<0){
// OVR, LPR, SYNC
SET_OVRTMR(timval);
delay_us((OVRoff-LPRoff)*-1);
SET_LPRTMR(timval);
} else {
// OVR, SYNC, LPR
SET_OVRTMR(timval);
delay_us(LPRoff);
SET_LPRTMR(timval);
} else {
// SYNC, OVR, LPR
delay_us(OVRoff);
SET_OVRTMR(timval);
delay_us(LPRoff-OVRoff);
SET_LPRTMR(timval);
} else if (OVRoff == LPRoff) {
if (LPRoff<0){
// LPRoff && OVRoff, SYNC
SET_LPRTMR(timval);
SET_OVRTMR(timval);
} else {
delay_us(LPRoff);
SET_LPRTMR(timval);
SET_OVRTMR(timval);
// enable interrupts
setup_timer_1(T1_INTERNAL | T1_DIV_BY_4 ); // Setup timer for LPR LL pulse
setup_timer_3(T3_INTERNAL | T3_DIV_BY_4 ); // Setup timer for OVR LL pulse
setup_timer_5(T5_INTERNAL | T5_DIV_BY_4 ); // Setup timer for SYNC pulse
enable_interrupts(INT_TIMER1); //enabel timer1 (16bit) interrupt to set LPR LL
enable_interrupts(INT_TIMER2); //enable timer2 (8bit) interrupt to reset LPR LL
enable_interrupts(INT_TIMER3); //enable timer3 (16bit) interrupt to set OVR LL
enable_interrupts(INT_TIMER4); //enable timer4 (8bit) interrupt to reset OVR LL
enable_interrupts(INT_TIMER5); //enable timer4 (8bit) interrupt to reset OVR LL
enable_interrupts(INT_TIMER6); //enable timer6 (8bit) interrupt to reset sync
enable_interrupts(INT_SSP); //enable i2c interrupt
config=1;
#INT_TIMER1
void TIMER1_isr() {
set_timer1(timval);
output_high(LL_LPR);
set_timer2(0); // set timer2 to reset the LPR linelock
#INT_TIMER3
void TIMER3_isr() {
set_timer3(timval);
output_high(LL_OVR);
set_timer4(0); // set timer4 to reset the OVR linelock
#INT_TIMER5
void TIMER5_isr() {
set_timer5(timval);
output_high(MCU1_SYNC);
set_timer6(0); // set timer6 to reset sync pulse
#int_TIMER2
void TIMER2_isr()
output_low(LL_LPR);
#int_TIMER4
void TIMER4_isr()
output_low(LL_OVR);
#INT_TIMER6
void TIMER6_isr()
output_low(MCU1_SYNC);
cerr
Posted: Fri Mar 18, 2011 4:36 pm |
Okay, I fiddled around a litte today and got my code to improve minorly until I replaced timer1 with timer7. That made a "huge" difference, and it works better now, not perfect but way better! Why does a replace make such a huge difference?
Timer7 & 3 are offset by about -50uS now and 7 & 5 about +150 so 5 & 3 are still 200uS apart - which is way out of tolerance :(
Thanks for help. I have pasted my updated code below:
#device ICD=TRUE, HIGH_INTS=TRUE, adc=16
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=DEBUG, ERRORS)
#define FREQMHZ 10
#define SET_LPRTMR set_Timer7
#define OFFSET_ARR_SZ 3
void long_delay_us(long count)
char i;
i = (char)(count >> 8);
while(i >= 1)
i--;
delay_us(253);
restart_wdt();
delay_us((char)count);
void main (void){
float period=0;
float fixval=0;
int1 config=0;
int16 LPRwdt=500;
int16 OVRwdt=500;
int16 SYNCwdt=500;
int16 delay[OFFSET_ARR_SZ]={0};
int8 order[OFFSET_ARR_SZ]={0};
int8 ctr=0;
int32 temp;
int32 iarray[OFFSET_ARR_SZ]={0};
while (true){
if (!config){
iarray[0]=0; //SYNC
iarray[1]=0; //LPR
iarray[2]=0; //OVR
iarray[0]|=0x10000000; // set SYNC ID bit
iarray[1]|=0x20000000; // set LPR ID bit
iarray[2]|=0x40000000; // set OVR ID bit
// Bubble sort offset times
for (ctr=0;ctr<OFFSET_ARR_SZ;ctr++) {
if ((iarray[ctr]&0x00FFFFFF) > (iarray[ctr+1]&0x00FFFFFF)) {
//Here a swap is needed
temp=iarray[ctr+1];
iarray[ctr+1]=iarray[ctr];
iarray[ctr]=temp;
int8 Freq=50;
fprintf(DEBUG, "LPRval %d\r\n",LPRval);
fprintf(DEBUG, "OVRval %d\r\n",OVRval);
fprintf(DEBUG, "SYNCval %d\r\n",SYNCval);
// extract delay time
delay[0]=iarray[0]&0x0FFFFFFF;
delay[1]=(iarray[1]&0x0FFFFFFF)-delay[0];
delay[2]=(iarray[2]&0x0FFFFFFF)-delay[1];
// extract the ID
order[0]=((iarray[0]&0xf0000000)>>28);
order[1]=((iarray[1]&0xf0000000)>>28);
order[2]=((iarray[2]&0xf0000000)>>28);
if (order[0]==0x1){
long_delay_us(delay[0]);
} else if (order[0]==0x2){
SET_LPRTMR(timval);
} else if (order[0]==0x4){
SET_OVRTMR(timval);
} else
fprintf(DEBUG"ERROR starting first timer0x%8x\r\n",(iarray[0]&0xf0000000));
if (order[1]==0x1){
long_delay_us(delay[1]);
} else if (order[1]==0x2){
SET_LPRTMR(timval);
} else if (order[1]==0x4){
SET_OVRTMR(timval);
} else
fprintf(DEBUG"ERROR starting second timer0x%8x\r\n",(iarray[1]&0xf0000000));
if (order[2]==0x1){
long_delay_us(delay[2]);
} else if (order[2]==0x2){
SET_LPRTMR(timval);
} else if (order[2]==0x4){
SET_OVRTMR(timval);
}else
fprintf(DEBUG"ERROR starting third timer0x%8x\r\n",(iarray[2]&0xf0000000));
setup_timer_7(T7_INTERNAL | T7_DIV_BY_4 ); // Setup timer for LPR LL pulse
enable_interrupts(INT_TIMER7); //enabel timer1 (16bit) interrupt to set LPR LL
enable_interrupts(INT_TIMER5); //enable timer5 (16bit) interrupt to reset OVR LL
config=1;
#INT_TIMER7 HIGH
void TIMER7_isr() {
set_timer7(timval);
#INT_TIMER3 HIGH
void TIMER3_isr() {
set_timer3(timval);
#INT_TIMER5 HIGH
void TIMER5_isr() {
set_timer5(timval);
#int_TIMER2 HIGH
void TIMER2_isr()
output_low(LL_LPR);
#int_TIMER4 HIGH
void TIMER4_isr()
output_low(LL_OVR);
#INT_TIMER6 HIGH
void TIMER6_isr()
John P
Posted: Fri Mar 18, 2011 8:38 pm |
If I were doing this, I'd use only one timer. What worries me here is that you can get all the timers clamoring for interrupts at the same time, and given the PIC's rather leisurely entry and exit to interrupts, you'll get significant inaccuracies.
If you just had the one timer, you'd want to calculate when the 6 events that make up a cycle need to occur (i.e. outputs A, B and C each going on and then off again). You'd calculate the intervals between each successive pair of events, and reset the timer appropriately every time it triggers.
But what if two events are very close, or simultaneous? Well, then you don't use the interrupt at all, but instead you execute a short delay while you're still in the interrupt, then perform the second operation. The program has to calculate when to use a new interrupt, versus when to stay in the interrupt and use a delay. It's not totally trivial, but that's what they pay you the big bucks to do.
Now, thinking ahead to the next product where there'll be different frequencies--you'll have to recalculate the intervals periodically. More fun! But I think it can still be done. |
cerr
Posted: Mon Mar 21, 2011 10:01 am |
John P wrote: | If I were doing this, I'd use only one timer. What worries me here is that you can get all the timers clamoring for interrupts at the same time, and given the PIC's rather leisurely entry and exit to interrupts, you'll get significant inaccuracies.
What about if i just use one interrupt to set the outputs (and timers) and then use 3 ISRs to reset the outputs appropriately - seems easier and more straight forward to me than calculating when which event (on & off) needs to occur... |
cerr
Posted: Mon Mar 21, 2011 10:52 am |
I tried it that way round now:
Have one timer to kick in a frequency, calculate the offset times and start the "reset timers" after the offset times to correctly reset the pulses after "width" time but I still seem to get somewhat inacurrate readings with my oscilloscope. Timer8 that's to reset the LPR_LL is jumping between ~200 and ~100 uSec back and forth... :( Why would that be? Any ideas?
The code now looks like this:
#define FREQMHZ 10
#define OFFSET_ARR_SZ 2
int16 delay[OFFSET_ARR_SZ+1]={0};
int8 order[OFFSET_ARR_SZ+1]={0};
int32 iarray[OFFSET_ARR_SZ+1]={0};
char i;
while(i >= 1){
i--;
delay_us(253);
restart_wdt();
void bubblesort(int8 arr_cnt, int32 *comb_arr)
int8 ctr;
int32 temp;
for (ctr=0;ctr<arr_cnt;ctr++) {
if (((*comb_arr)[ctr]&0x00FFFFFF) > ((*comb_arr)[ctr+1]&0x00FFFFFF)) {
temp=comb_arr[ctr+1];
(*comb_arr)[ctr+1]=(*comb_arr)[ctr];
(*comb_arr)[ctr]=temp;
void main (void){
float period=0;
float fixval=0;
int1 config=0;
int16 LPRwdt=200;
int16 OVRwdt=200;
int16 SYNCwdt=200;
int8 Freq=50;
int8 ctr=0;
int32 temp;
while (true){
if (!config){
iarray[0]=0; //SYNC
iarray[1]=500; //LPR
iarray[2]=200; //OVR
bubblesort(OFFSET_ARR_SZ, iarray);
/** calculate timer value for frequency **/
/** calculate timer values for pulse widths **/
// extract offset delays
// extract offset ID
//setup timers
setup_timer_8(T8_DIV_BY_16, LPRval, 1); // Setup timer for LPR LL pulse
enable_interrupts(INT_TIMER8); //enable timer8 (8bit) interrupt to reset LPR LL
config=1;
#INT_TIMER3 HIGH
void TIMER3_isr() {
set_timer3(timval);
/** start "reset timers" in correct order **/
if (order[0]==0x1){
} else
if (order[1]==0x1){
} else
if (order[2]==0x1){
}else
#int_TIMER4 HIGH
void TIMER4_isr()
output_low(LL_OVR);
#INT_TIMER6 HIGH
void TIMER6_isr()
#int_TIMER8 HIGH
void TIMER8_isr()
output_low(LL_LPR);
Thanks for your continued support...
If this isn't the way to go and you would stick to using one timer only, how would you recommend to resolve the "reset problem" meaning,
I can bubble sort the offsets to know when to start but how would i bubble sort the width in there to properly reset the pins?
Thanks! |
cerr
Posted: Mon Mar 21, 2011 12:19 pm |
Okay,
I got somewhat accurate readings now, I was reguired to reset the timers to 0 whenever i call setup_timerX() and I set the ISRs 4,6 & 8 as high priority but timer3 is still low.
But still I don't get very accurate timings. I'm wondering if it's because my MCU is clocked with 10MHz "only".
If I set the pulse to be 200uS - my oscilloscope measures about 235uS which is 17.5% off... if I could achieve more accuracy, that would be awesome - i of course could put a correction factor in there (when calculating the timer values)but I don't know if that's really what i want... Also this is just a "dev project" and the final hardware will have a 20MHz oscillator...
Any hints or suggestions? |
