PIC Startup
sandy wilson
PIC Startup
PostPosted: Mon Mar 07, 2011 4:57 am     Reply with quote
I'm having a problem running the code stand alone in a PIC 18F8720.
If we use an ICD-U64 to program the PIC through CCLoader and then run the code through CCLoader the code will run as expected. If we then program the PIC using CCLoader, diconnect the ICD and then try to run the code stand alone the code will not run . The MCLR etc is coming to the right values, we have NoDebug set in the fues.
Any suggestions why the code will not run stand alone?
Cheers
Sandy Wilson Confused
PostPosted: Mon Mar 07, 2011 6:24 am     Reply with quote
Two ideas..
1) Remove the use ICD=true line in your program.
2) If using MPLAB to facilitate programming the PIC, you'll have to edit the 'build option' from 'debug' to 'release' AND recompile(F10), then program the PIC.
