cerr
Joined: 10 Feb 2011 Posts: 241 Location: Vancouver, BC
| 18f8722->18j87k22 |
Posted: Thu Feb 24, 2011 12:05 pm |
Hi There,
I'm porting my code from an 18f8722 to an 18f87k22. I assume it should be working pretty much the same but the first problem is, the K version doesn't take:
#FUSES HS
and
#FUSES NOLVP
the header file says:
Fuses: SOSC_HIGH,NOXINST,XINST,LP,XT,HSH,HSM,ECH,ECH_IO,RC,RC_IO
but I'm not sure of the difference between hsh or HSM. What should I be using? I'm using a 10MHz crystal oscillator. Also, what about the NOLVP/ Can I just leave it out?
Thanks! |
Posted: Thu Feb 24, 2011 12:40 pm |
Download the PIC data sheet.
Type this into Google:
That takes you to the web page for that PIC and the data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39960b.pdf
Look in the oscillator section:
| Quote: |
3.1 Oscillator Types
HS1 is the Medium power mode with a frequency range
of 4 MHz to 16 MHz. HS2 is the High-Power mode, where
the oscillator frequency can go from 16 MHz to 25 MHz.\
So it's obvious that CCS has renamed the modes (for some strange
reason) to HSM (medium) and HSH (High power). |
cerr
Posted: Thu Feb 24, 2011 12:49 pm |
| PCM programmer wrote: | Download the PIC data sheet.
| Quote: |
Thank you, I was looking at the datasheet and got confused why it would be HSH & HSM instead of HS1 & HS2 but your solution sounds like a possible way to go......
Thanks |
cerr
Posted: Thu Feb 24, 2011 1:07 pm |
However, non of them seems to be the correct one either. I can tell by getting a weird character on my rs-232 at 9600 baud and I set a pin high for 200us but it's up for ~50us only. I'm looking at it with my scope....any other clues maybe?
Thanks! |
Posted: Thu Feb 24, 2011 1:46 pm |
Well, that's a clue. It's running 4x faster than expected. Again, look in
the PIC data sheet. Look for something that makes it run 4x faster.
Data sheet says:
| Quote: |
There is also an option for running the 4xPLL on any of
the clock sources in the input frequency range of 4 to
16 MHz.
The PLL is enabled by setting the PLLCFG bit
(CONFIG1H<4>) or the PLLEN bit (OSCTUNE<6>). |
Then look at the end of your .LST file, to see what fuses the compiler
is using. It's obvious that it's enabling the PLL:
| Quote: | Configuration Fuses:
Word 1: D31D VREGSLEEP INTRC_HP SOSC_HIGH NOXINST HSM PLLEN FCMEN IESO
Word 2: 7C7E PUT BROWNOUT BORV18 ZPBORM NOWDT WDT1048576
Word 3: 8BF9 RTCOSC_T1 EXTADDRSFT ABW20 BW16 NOWAIT CCP2C1 ECCPE MSSPMSK7 MCLR
Word 4: 0091 STVREN BBSIZ2K NODEBUG
Word 5: C0FF NOPROTECT NOCPB NOCPD
Word 6: E0FF NOWRT NOWRTC NOWRTB NOWRTD
Word 7: 40FF NOEBTR NOEBTRB |
Next, look at the top of the 18F87K22.h file and look for a fuse setting
that will disable the PLL. Add that to your #fuses statement. |
cerr
Posted: Thu Feb 24, 2011 2:00 pm |
| PCM programmer wrote: | Well, that's a clue. It's running 4x faster than expected. Again, look in
Data sheet says:
| Quote: |
16 MHz.
That was the way to go. I'm sorry, I'm asking stupid questions but I've only been using CCS for a couple of days and need to find my ways around first... Thank you very much tho for the patient answer! It properly resolved my issue!  |
