Testing for overflow in 16 and 32 bit maths
levdev
PostPosted: Tue Feb 15, 2011 4:51 pm     Reply with quote
I have the code:
   int16 a, b, c;
   c=a+b;
or
   int16 a, b, c;
   c=a-b;
how can I tell if my int16 c has overflowed?
Testing the Status bits doesn't seem to work (possible because it's a 16 bit sum rather than 8 bit).
PostPosted: Tue Feb 15, 2011 5:32 pm     Reply with quote
The C FAQ has a section on integer math overflow:
http://c-faq.com/misc/intovf.html
FvM
PostPosted: Wed Feb 16, 2011 2:51 am     Reply with quote
Why do you think that that status register bits (C and OV) aren't valid for multi byte arithmetic. The status value after an arithmetic operation holds the result of MSB processing, which in fact does inform about signed overflow or unsigned carry.
levdev
PostPosted: Wed Feb 16, 2011 9:21 am     Reply with quote
On further investigating I have found that you are right FvM, the status register bits are valid for multi byte arithmetic. The problem was I was using the SFR tab in the debug window which doesn't seem to give a true value of the STATUS register, even if you set a breakpoint and use the refresh button.
Thanks for your reply.
PostPosted: Wed Feb 16, 2011 12:52 pm     Reply with quote
Are you proposing that in the C language, we can depend upon machine
level flags being persistent and available at the C language source level ?
SherpaDoug
PostPosted: Wed Feb 16, 2011 1:59 pm     Reply with quote
It may work, but I would not consider it good C programming form to depend on the overflow flag. It would be better to design the data path so overflow will never happen.
levdev
PostPosted: Wed Feb 16, 2011 2:39 pm     Reply with quote
One of the calculations I am doing is a simple Pythagoras calculation:
int16 a,b,c;
int32 a2, b2, c2;
a=get_val_from_sensor_a();
b=get_val_from_sensor_b();
a2=_mul(a2,a2);
b2=_mul(b2,b2);
c2=a2+b2;
c=sqrt32(c2);
Now if a2+b2>2^32-1 then c2 will overflow. In my case if it overflows I don't need to know the value as it is out of range, so I could set it to the maximum value 2^32-1. But how do I know if it overflows? At the moment I am testing the STATUS register which seems to be working OK. I can't pre-test the a and b values because the expression combines to the two sqaures so only by calculating this expression can you get the result. I don't want to get into using 64 bit maths on a PIC18F. I suppose I could divide the a and b values by two before squaring and then double c at the end, but then I will lose some precision.
Any other suggestions would be appreciated.
newguy
PostPosted: Wed Feb 16, 2011 3:10 pm     Reply with quote
int16 a,b,c;
int32 a2, b2, c2;
a2=_mul(a2,a2);
b2=_mul(b2,b2);
c2=a2+b2;
c=sqrt32(c2);
Easy. Check to see if the result (a^2 + b^2) is less than either a^2 or b^2. If it is, there was an overflow. It's not a valid test for all combinations of a & b, but it's probably sufficient most of the time.
