software uart with INT_RDA
okayazu
PostPosted: Mon Feb 14, 2011 11:28 am     Reply with quote
Hello!
I need to use uart 2 port so I will use software uart (I use 16F877A).
If xmit=PIN_C6, rcv=PIN_C7, this code can use
but when I use like this, it can't receive string so I want to ask everybody.
What can I do? and How to write the code?
Please give some example to me.
Thank you so much.
#include <16F877A.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5, stream=COM)
#define relay_door      PIN_B0
#define magnetic_elec   PIN_B1
char close_e[5];
char open_e[5];
char order_e[5];
BOOLEAN rx_int = FALSE;
#INT_RDA
void RS232_isr(void)
    gets(order_e);
    rx_int = TRUE;
void main(char order_e)
   int v;
   int w;
   set_tris_b(0x00);
   set_tris_a(0x00);
   output_b(0x00);
   enable_interrupts(INT_RDA);
   strcpy(close_e,"0100");
   strcpy(open_e,"01FF");
   printf("\r\n Hello");
      printf("\r\n MOVE to WHILE TRUE");
      printf("\r\n ENTERED ORDER is \"%s\"",order_e);
      while(!rx_int)
            output_toggle(PIN_A0);
     if(rx_int) // True or False not 1 or 0
         printf("\r\n RX_INT TRUE");
         v = strcmp(order_e,open_e);
         printf("\r\n V is %d",v);
          if (v == 0)
               printf("\r\n ENTERED ORDERE is \"%s\"",order_e);
               output_high(PIN_B0);
          else if(v != 0 )
               w = strcmp(order_e,close_e);
               printf("\r\n W is %d",w);
                  if (w == 0)
                     output_high(PIN_B1);
                     printf("\r\n read command or file name");
      printf("\r\n End Process");
      rx_int = FALSE;
FvM
PostPosted: Mon Feb 14, 2011 11:42 am     Reply with quote
Of course, INT_RDA can't work with software UART. But it's also a bad idea to use gets() inside an ISR function with hardware UART. It won't return from interrupt and thus block the processor until the final carriage return. You would want to use a RX buffer in this case.
