Out of memory error?
bdrmachine
PostPosted: Sun Jan 30, 2011 5:58 pm     Reply with quote
I had a working program before I switched processors from a 18f2550 (32k flash) to a 18f26k22 (64k flash). Even though the memory size doubled I get the following error:
Executing: "C:\Program Files (x86)\PICC\Ccsc.exe" +FH "main.c" #__DEBUG=1 +ICD +DF +LN +T +A +M +Z +Y=9 +EA #__18F26K22=TRUE >>> Warning 203 "main.c" Line 136(1,1): Condition always TRUE *** Error 71 "main.c" Line 454(2,3): Out of ROM, A segment or the program is too large MAIN Seg 00004-01CBE, 018A left, need 0568 Seg 00000-00002, 0000 left, need 0568
What am I doing wrong?
PostPosted: Sun Jan 30, 2011 6:21 pm     Reply with quote
Do a test. Run this program in MPLAB simulator and see what the
compiler thinks the Program Memory size is:
#include <18F26K22.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
printf("ROM size is: %lx \r", getenv("PROGRAM_MEMORY"));
Also post your compiler version.
bdrmachine
PostPosted: Sun Jan 30, 2011 8:03 pm     Reply with quote
The memory usage gauge reads 121 bytes using version 4.111
bdrmachine
PostPosted: Sun Jan 30, 2011 8:05 pm     Reply with quote
Sorry I forgot to add the compiler states 3%
The output from the printf is "ROM size is: 1cc0"
bdrmachine
PostPosted: Mon Jan 31, 2011 7:30 am     Reply with quote
Where is the compiler getting its' part specific memory size. Is this pulled from the top part of the header file? I did notice that the ram size was stated as 512. I changed it to 3896 as stated in the data sheet. This had no change to the out of rom error. One thing I noticed is that the error is always reported as being 2 lines past the end of the file. e.g. if my main .c file is 455 lines long it reports the error at line 457. If I delete any 4 lines the error reports line 443.
dyeatman
PostPosted: Mon Jan 31, 2011 7:43 am     Reply with quote
The size comes from the devices.dat file, not from the header. My header
(in version 4.114) shows 512 RAM but the devices.dat files shows the correct
amount (3896). If you have the IDE you can view/edit the file using the
device editor. I am not in a position right now to load 4.111 to check the
devices.dat file for that version.
Google and Forum Search are some of your best tools
levdev
PostPosted: Tue Feb 08, 2011 3:49 am     Reply with quote
I have a similar problem converting from a PIC18F26K20 to a PIC18F26K22. My ROM usage goes from 10% to 90%, but the output code is the same size.
I found that removing the directive
#device ICD=true
fixed the problem, but obviously disables the debug capability. I have emailed CCS about the problem and will post a reply here once I get one.
bdrmachine, did you have this directive in your code, and does removing it solve the problem for you? Have you found another resolution to this problem?
