| ivaneduardo747
				| Passing a string array to a function |
				|  Posted: Sat Feb 05, 2011 3:36 pm |   |
				| How can I pass a string array like:
  	  | Code: |  	  | const char colors[] [*] = {"Red", "Green", "Blue"};
 Into a function? How the syntax would be like?
 How to access it inside the function?
 Also, is there any way I can get the number of elements inside an array?
 Thanks!
 0x2BE NOR 0X2BE
		| PCM programmer
				|  Posted: Sun Feb 06, 2011 2:40 pm |   |
				| I tested the program shown below in MPLAB simulator and got the following output.  This was tested with PCH vs. 4.118.
  	  | Code: |  	  | #include <18F452.h>
 #device PASS_STRINGS=IN_RAM
 #fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
 int8 i;
 for(i = 0; i < 3; i++)
 printf("%s \r", colors[i]);
 I don't know how to get the number of elements from a 'const'
 2-dimensional array in CCS. I don't know if it's possible.
