Pic24HJ256GP610 Oscillator Fuses
pieter
PostPosted: Fri Jan 21, 2011 2:21 pm     Reply with quote
If you can help, with the following, it will be highly appreciated
I set up the fuses correctly but MPLab shows the fuses are different.
It shows Primary Osc = disabled (wrong)
primary clock = FRC (wrong)
but PLL shows enabled (correct)
My fuses are:
#FUSES WDT                         //Watch Dog Timer
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOBSS                     //No boot segment
#FUSES NOPROTECT             //Code not protected from reading
#FUSES XT
#FUSES PR_PLL                     //Pimary oscillator
#FUSES NOOSCIO                 //OSC2 is general purpose output
#FUSES WPRES128                //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16               //Watch Dog Timer PostScalar 1:32768
#FUSES PUT128                   //Power On Reset Timer value 128ms
#FUSES NOIESO                   //Internal External Switch Over mode #FUSES NORSS                    //No secure segment RAM
#FUSES NOSSS                    //No secure segment
#FUSES NOWRTSS                //Secure segment not write protected
#FUSES NORBS                    //No Boot RAM defined
#FUSES NODEBUG                //No Debug mode for ICD
etc.
#use delay(clock=40M, Oscillator=10M,RESTART_WDT)
The micro runs at 5 times lower speed to what is programmed
On a few other but different Pic24 microcontrollers it works correct.
Any ideas?
PostPosted: Fri Jan 21, 2011 4:29 pm     Reply with quote
I couldn't reproduce what you said about different fuse bits in MPLAB, so apparently your using a different PCD version,
or something else is different. Obviously it's useless to check the other points then.
I may want to look into it further, if you
-tell the involved PCD version
-post a complete compilable example that reproduces the issue
pieter
PostPosted: Sat Jan 22, 2011 1:22 am     Reply with quote
Thank you for helping
I am using Pcd 4.107
Printf == >= ! functions and expressions do not work correctly either
PostPosted: Sat Jan 22, 2011 3:40 am     Reply with quote
PCD V4.107 doesn't set the PLL parameters for your chip according to #use delay, newer versions (e.g. V4.112) do.
I can't see a problem with #fuses in V4.107, however.
Setup_oscillator() also doesn't work correctly with V4.107, so you have to write to CLKDIV and PLLFBD directly.
Some other bugs (e.g. arithmetic) are also present with V4.107. I'll check V4.118 next days.
