DC motors with L293D not running..
talhahs
PostPosted: Sun Jan 09, 2011 3:18 pm     Reply with quote
Hi all, what could make this code from not running properly??
H bridge: L293D
2 DC motors connected to each side of L293D.
It waits for corresponding character from VB app before taking the action.
#include "C:\Documents and Settings\Talha\My Documents\codes_CCS\VB_DC motor all directions\vb_motor_all directns.h"
#define LEFT_CONTROL_2A  PIN_C0  //2A of L293D
#define LEFT_CONTROL_1A  PIN_C1  //1A
#define LEFT_MOTOR       PIN_C2  //1,2EN
#define LED PIN_D1
#define RIGHT_MOTOR      PIN_D4  //3,4EN
#define RIGHT_CONTROL_4A PIN_D5  //4A
#define RIGHT_CONTROL_3A PIN_D6 //3A
void backward()
{         output_low(LEFT_CONTROL_1A);
          output_high(LEFT_CONTROL_2A);
          output_low(RIGHT_CONTROL_3A);
          output_high(RIGHT_CONTROL_4A);
          output_high(LEFT_MOTOR);
          output_high(RIGHT_MOTOR);
void forward()
{         output_high(LEFT_CONTROL_1A);
          output_low(LEFT_CONTROL_2A);
          output_high(RIGHT_CONTROL_3A);
          output_low(RIGHT_CONTROL_4A);
void left()
void right()
void reset()
          output_low(LED);
          output_low(LEFT_MOTOR);
          output_low(RIGHT_MOTOR);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   char cmd;
do{
  if(kbhit())
{    cmd=getch();
output_high(LED);
      switch (cmd)
 case '0': //backward
 printf("backward");
           reset();
           backward();
 case '1': //forward
 printf("forward");
 reset();
             forward();
case '2': //left
 printf("left");
reset();
            left();
case '3': //right
 printf("right");
reset();
         right();
case '4': //stop
 printf("stop");
         reset();
} while(1) ;
PostPosted: Sun Jan 09, 2011 3:29 pm     Reply with quote
Post this file:
We need to see the #include line for your PIC, the #fuses, #use delay(),
#use rs232(), etc.
Also post your CCS compiler version.
talhahs
PostPosted: Mon Jan 10, 2011 2:05 am     Reply with quote
Compiler version: PCWHD 4.104
#include <16F877A.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT                    //No Power Up Timer
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(clock=12000000)
PostPosted: Mon Jan 10, 2011 3:34 am     Reply with quote
Glaring thing, you _must_ have 'errors' in your RS232 definition.
Generally, this should _always_ be used, unless _you_ are handling UART errors yourself.
In your case, not having it, will almost certainly hang the UART. Problem is the long delays. You have delays for the prints, and long timing delays in the code. If more than two characters arrive in any of these, the UART _will_ be hung....
PostPosted: Mon Jan 10, 2011 6:52 am     Reply with quote
Do you have a MAX232 or equal on the serial I/O lines?
Serial cable is wired correctly?
Are you sure the VB program is sending an ASCII 0...4 ?
Have you tried hyperterminal or another terminal software package?
Try a loopback echo program to be sure..even have the PIC do it, before executing the case code...
I'd add a case 'else' statement to turn off the motors for invalid commands.
