LTS-Phil
| VNC1L-A via SPI on 18f4550 |
Posted: Thu Jan 06, 2011 8:31 am |
Hi!
As a part of my diploma project I have to send some data accumulated on a SD-card to a USB-Stick.
I decided to use a Vinculum VNC1L-A to store the datas...
I am not able to use the UART-Bus cause there are not enough free pins on the PIC.
The problem I have is:
I got nearly no idea how to setup the SPI-bus. There's simply no code on the internet that uses ccs-c for using the SPI-bus to connect with the vnc1l.
Has anyone of you got a sample-code that creates a *.txt file via the SPI-Bus or somthing similar?
greetz, Phil |
