rafaluc
| RS232 |
Posted: Mon Jan 03, 2011 5:51 am |
| Which the difference between putc and putchar. |
SherpaDoug
Posted: Mon Jan 03, 2011 8:05 am |
There is no functional difference, only aesthetic. I think if you look in the header files you will find putc is defined as putchar. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Mon Jan 03, 2011 9:29 am |
It is 'historical'.
putchar, is originally defined in K&R, as being equivalent to putc(c, stdout).
putc, in the original C implementation was equivalent to fputc, and required a stream name. On the standard C implementation, you always had three streams defined. stdin, stdout, and stderr (error output). If you just wanted to talk to stdout, and didn't want to type the name, you just use putchar.
In CCS, they are identical.
