How to pull up port A in 16F819 by program?
sorasit46
PostPosted: Wed Dec 29, 2010 6:16 pm     Reply with quote
16F819
port_b_pullups(TRUE);
How to program pull up port A ?
thanks
PostPosted: Wed Dec 29, 2010 7:12 pm     Reply with quote
You have easy two options that I can quickly think of.
Use external resistors of the appropriate value for your particular application and PIC,be sure to read the datasheet for correct inforamtion
or
Read the datasheet, hint, I/O PORTS section, PORTA, first chapter. In there is a wealth of specific information on the subject.
After over 50 years of building 'stuff' and inhaling solder fumes I've always found that reading the manual is the FIRST thing you should do when 'playing with chips'.
scottc
PostPosted: Wed Dec 29, 2010 7:18 pm     Reply with quote
You can't in software
Page 39 of the data sheet,
http://ww1.microchip.com/downloads/en/DeviceDoc/39598e.pdf
There are no weak pullups for port a.
Weak Pullups do exist for Port B.
If you need to pull the pin up then you will have to use an external
resistor to VCC, a value of 47K should be ok.
Scott
sorasit46
PostPosted: Fri Dec 31, 2010 12:17 am     Reply with quote
Thanks and happy new year.
