sniffer
| picKit 2 UART tool dsPIC33 |
Posted: Thu Apr 01, 2010 3:45 pm |
I am starting up a project with dsPICFJ128GP802 and I've made all the basic connections. I'm using PIC Kit 2 to power it up and the first thing I wanted to do is to use PICKit 2 UART tool to send a character to the UART screen. Here's my code:
#include <33fj128gp802.h>
#fuses HS, NOWDT, PR_PLL, NOPUT
#use delay (clock=20000000)
#use rs232(baud=9600, XMIT=PIN_B0, RCV=PIN_B1, ERRORS)
putc('n');
output_toggle(PIN_B4);
delay_ms(2000);
I have an LED connected to pin B4 and its doing the toggle correctly.
Here is what I'm getting in the UART Tool screen
| Quote: | ?????????
RX: FD
RX: FD
RX: FD
RX: FD |
The ? is when I select the ASCII mode and RX: FD is in Hex mode. Does anyone have an idea on why I am getting the '?' instead of 'n' ? It's the same no matter what character or number I put. Thanks in advance.
My compiler version is PCD 4.084, 57706. |
sniffer
| picKit 2 UART tool dsPIC33 (SOLVED) |
Posted: Mon Apr 05, 2010 6:24 pm |
| I had the fuse setting wrong. I should have used PR instead of PR_PLL. Changed it and now its working. |
sniffer
Posted: Mon Apr 05, 2010 9:12 pm |
I'm having another simple problem and I also connected MAX233 and used a serial cable instead of using PIC Kit's UART tool because I didnt trust the tool very much, but I am still having the problem.
#fuses HS, NOWDT, PR, NOPUT
#use delay (clock=20M)
#use rs232(baud=9600, XMIT=PIN_B7, RCV=PIN_B6, ERRORS)
printf("Hello");
delay_ms(2000);
On the Serial Port Monitor, what's happening is that "Hello" is being displayed only once when the program initially runs and then the program does nothing. However, if I print "Hel" or any other 3 characters then the program works fine as intended. As soon as I try to print 4 or more characters it doesn't work. I had this problem with PICKit's UART tool as well which is why I switched to a regular serial port instead. Any clues on what may be causing this odd behavior?
The PIC runs at 3.3v and MAX233 is powered up with 5V, I've connected output of MAX233 to PIC's 5V tolerable pins B6 and B7. |
sniffer
Posted: Tue Apr 06, 2010 8:23 pm |
I tried to see if I could find anything from the .lst file. I noticed that the generated code are similar when I have printf("Hel") or printf("He"). But when I have printf("Hell") or more than 4 characters, then the .lst file is different.
I have pasted parts of the .lst file below for all 3 cases, could anyone please recompile my code using a different PCD compiler and see if you get the same kind of code for the 3 cases?
For printf("He):
.................... while(TRUE)
.................... printf("He");
00244: MOV.B #48,W0L
00246: MOV.B W0L,801
00248: CALL 200
0024C: MOV.B #65,W0L
0024E: MOV.B W0L,801
00250: CALL 200
.................... delay_ms(2000);
00254: MOV #7D0,W0
00256: CALL 224
0025A: GOTO 244
For printf("Hel"):
.................... printf("Hel");
00248: CALL 200
00250: CALL 200
00254: MOV.B #6C,W0L
00256: MOV.B W0L,801
00258: CALL 200
0025C: MOV #7D0,W0
0025E: CALL 224
00262: GOTO 244
For printf("Hell"):
.................... printf("Hell");
00256: MOV #0,W1
00258: MOV W1,W0
0025A: CALL 200
0025E: INC W1,W1
00260: MOV.B W0L,801
00262: CALL 212
00266: MOV #3,W0
00268: CPSGT W1,W0
0026A: BRA 258
0026C: MOV #7D0,W0
0026E: CALL 236
00272: GOTO 256 |
Please let me know if you need more parts of the code. Thanks. |
Rohit de Sa
Posted: Thu Apr 08, 2010 9:29 pm |
My speculation: It looks like for 3 of less characters the compiler stores the characters 'inline'. #48, #65, and #6C correspond to 'H', 'e', and 'l'. For more than 3 characters, the code becomes more compact if the compiler creates a loop and accesses successive characters stored elsewhere.
Rohit |
gpsmikey
Posted: Wed Dec 22, 2010 2:12 pm |
| Quote: | | I'm using PIC Kit 2 to power it up and the first thing I wanted to do is to use PICKit 2 UART tool |
Not sure if this applies here, but in a somewhat older readme for the PICkit2, on using the UART Tool I just came across, I found the following comment:
| Quote: | IMPORTANT CONNECTION NOTES:
PICkit2 cannot supply Vdd when using the UART Tool. The PICkit 2 Vdd pin MUST be connected to the target UART Vdd or it will NOT work |
I just happened across this in doing some research on the UART tool also
http://ww1.microchip.com/downloads/en/DeviceDoc/PICkit%202%20Readme%20v2-40.txt
mikey _________________ mikey
