Joined: 01 Jul 2010 Posts: 9130 Location: Greensville,Ontario
Posted: Tue Jan 10, 2017 5:46 am |
some Qs
1) does your PIC run a '1Hz LED program' correclty ?
2) does that PIC use 'pin_select'?
3) delete the PROTECT fuse ! Search here for why or read the datasheet
4) what's the code for the serial port for? Does it work without the DS code ?
kanzay
To use more than one DS18B20 in one Pic with different Pins |
Posted: Tue Jan 23, 2018 2:31 pm |
To use more than one DS18B20 in one Pic with different Pins.
Ii have more pins free so i found a solution like this.
İ found codes from many different websites so they are not written by me, i just added some code.
You may see original post
Code: | #include <16f876A.h>
#device adc=10
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use fast_io(a)
#define LCD_ENABLE_PIN PIN_B2
#define LCD_RW_PIN PIN_B1
#define LCD_RS_PIN PIN_B0
#define LCD_DATA4 PIN_B4
#define LCD_DATA5 PIN_B5
#define LCD_DATA6 PIN_B6
#define LCD_DATA7 PIN_B7
#define ONE_WIRE_PIN PIN_C2
#define ONE_WIRE_PIN1 PIN_C3
#define use_portb_lcd TRUE // LCD B portuna bagli
#include "lcd.c" // LCD kütüphanesinin eklenmesi
float sicaklik,eskisicaklik; // Kullanýlan deðiþkenlerin tanýmlanmasý
int8 sensor=0;
void onewire_reset()
if(sensor==0)
output_low(ONE_WIRE_PIN);
delay_us( 500 ); //1-wire resetleme için sıfıra çekilir
output_float(ONE_WIRE_PIN); //1-wire bir yapılır
delay_us( 500 ); // sensörün hazırlanması için beklenir.
if (sensor==1)
output_low(ONE_WIRE_PIN1);
output_float(ONE_WIRE_PIN1); //1-wire bir yapılır
void onewire_write(int data)
int count;
if (sensor==0)
for (count=0; count<8; ++count)
delay_us( 2 ); // Sensöre yazma işlemine başlamak için 1-wire sıfıra çekilir.
output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // yazılacak bilgi 1-wire'da
delay_us( 60 ); // Yazma işlemi zamanı doldurulur.
output_float(ONE_WIRE_PIN); // 1-wire bir yapılır,
delay_us( 2 ); // 1us'den fazla beklenir.
if (sensor==1)
output_bit(ONE_WIRE_PIN1, shift_right(&data,1,0)); // yazılacak bilgi 1-wire'da
output_float(ONE_WIRE_PIN1); // 1-wire bir yapılır,
int onewire_read()
int count, data;
if (sensor==0)
delay_us( 2 ); //Sensördem okuma işlemi içinl 1-wire sıfıra çekilir.
output_float(ONE_WIRE_PIN); //1-wire bir yapılır,
delay_us( 8 ); // Sensörün kendine gelmesi beklenir,
shift_right(&data,1,input(ONE_WIRE_PIN)); // sonuc bilgisi alınır.
delay_us( 120 ); //Okuma işlemi zamanı doldurulur.
if (sensor==1)
output_float(ONE_WIRE_PIN1); //1-wire bir yapılır,
shift_right(&data,1,input(ONE_WIRE_PIN1)); // sonuc bilgisi alınır.
return( data );
float ds1820_read()
int8 busy=0, temp1, temp2;
signed int16 temp3;
float result;
onewire_reset();
onewire_write(0xCC);
onewire_write(0x44);
while (busy == 0)
busy = onewire_read();
onewire_reset();
onewire_write(0xBE);
temp1 = onewire_read();
temp2 = onewire_read();
temp3 = make16(temp2, temp1);
result = (float) temp3 / 16.0;
delay_ms(200);
return(result);
lcd_init(); // LCD'nin çalýþmasý hazýrlanmasý
printf(lcd_putc,"ODA TERMOSTATI"); // Ekrana belirtilen yazýlarýn gönderilmesi
printf(lcd_putc,"\nGELISTIRILIYOR"); // Yazýnýn baþýna eklenen \n komutu bir alt satýra geçmesi içindir.
printf(lcd_putc,"\f");
printf(lcd_putc,"IC SICAKLIK");
printf(lcd_putc,"\nDIS SICAKLIK");
printf(lcd_putc,"\f"); // Ekraný silme komutu
while (1)
sensor=0;
sicaklik = ds1820_read(); // ds1820_read() fonksiyonu bize sýcaklýk bilgisini verir bu bilgiyi sicaklik olarak tanýmladýðýmýz deðiþkene atýyoruz
if (eskisicaklik!=sicaklik) { // Ekranýn sadece sýcaklýk deðiþtiðinde yenilenmesi için 2. deðiþken ile karþýlaþtýrýlmasý. Eðer deðiþim var ise ekranýn yenilemesi.
lcd_gotoxy(1,1); // Ekranýn yazmaya baþlamasý için 1. Satýr 1. Sütuna gitmesine yarayan fonksiyon.
printf(lcd_putc,"\IC_ISI: %4.2fC", sicaklik); // Okunan Sýcaklýk bilgisi ekrana yazdýrýlýyor.
eskisicaklik=sicaklik; // Ekranýn sadece sýcaklýk deðiþtiðinde yenilenmesi için 2. bir deðiþkene atýyoruz.
delay_ms(4000);
sensor=1;
lcd_gotoxy(1,2); // Ekranýn yazmaya baþlamasý için 1. Satýr 1. Sütuna gitmesine yarayan fonksiyon.
printf(lcd_putc,"DIS_ISI: %4.2fC", sicaklik); // Okunan Sýcaklýk bilgisi ekrana yazdýrýlýyor.
delay_ms(250);
Posted: Tue Jan 23, 2018 6:05 pm |
What is being done is copying and editing the driver for as many sensors as required. This is the easy way and works very well. I did this 5-6 years ago. While it does require more code space it ensures the correct timing for the devices
