A button with several functions
bauche
PostPosted: Fri Nov 19, 2010 8:36 pm     Reply with quote
Hello, does anyone have an idea about how to make a button with two functions?
if (variable _1 >=1)
PIN_A3 = STOP;
PIN_A3 = SET_TIMER;
and also if you press the button for more than two seconds it
changes state.
#define  START       (input(PIN_A3))
Thank you for any hints...
vinniewryan
PostPosted: Fri Nov 19, 2010 10:09 pm     Reply with quote
Well, if I understand correctly, something like this should do the trick:
int8 secondspassed=0;
int16 buttontimer=0;
int1 button=0;
if(input(PIN_A3)) //button has been pressed
   button=1;
   if(buttontimer>xxx) //how ever many timer cycles are in 1 second
      //or you can use a hardware timer
      secondspassed++;
      buttontimer=0;
      buttontimer++;
   if(button==1) //button has been released
      button=0;
      if(secondspassed<2) //button was NOT held down for 2 seconds
         if(variable_1>=1)
            stop();
            set_timer();
      else //the button HAS been held down for 2 seconds
          //do something here
   else //the button is not currently being pressed
      secondspassed=0; //reset
This code is not tested, but it's a general idea of how you would call different functions depending on different button conditions.
Vinnie Ryan
PostPosted: Sat Nov 20, 2010 9:19 pm     Reply with quote
Does anyone have an idea about how to make a button with two functions?
If you press the button for more than two seconds it changes state.
This thread has code, and links to other code, for a button with several features:
http://www.ccsinfo.com/forum/viewtopic.php?t=42027
