OpenSys
| 74hc595 + pic18f4620 + enc28j60, 74hc595 dont work |
Posted: Tue Oct 26, 2010 3:06 pm |
hello,
I have problems to get the 74hc595 working.
I have the pic18f4620 + enc28j60 working good, but im unable to put the 74hc595 working.
Question:
Can I use the CLK and SDO of the pic to connect to 74hc595 ?
I question this because this data lines was already connected to the enc28j60.
I have the storage register clock (ST_CP) connected to pin 21, D2 on pic but in 74595.c include file I don't see any code to send the data to 74hc595 pin.
ex:
#define EXP_OUT_ENABLE PIN_D3 //pin 22
#define EXP_OUT_CLOCK PIN_C3 // pin18
#define EXP_OUT_DO PIN_C5 //pin 24
#define NUMBER_OF_74595 1
I have the pin 13 OE of 74hc595 to the ground
One thing that appends is, if I pass my fingers on pic over close the 21 pin all the led connect to the 74hc595 will blink... strange thing.
I see all the examples in the forum about it, but I'm unable to find to solution on it.
A help will be good appreciated.
Thanks,
VS |
Posted: Tue Oct 26, 2010 4:08 pm |
Here are the connections required by the 74595.c driver:
Signal name on PIC 74HC595 pin
EXP_OUT_ENABLE ST_CP
EXP_OUT_DO DS
EXP_OUT_CLOCK SH_SP
Other signals
+5v /MR
Ground /OE
You don't need to use the hardware SPI pins. The 74595.c driver
uses "bit banging" to send the data. It does not use hardware SPI.
Also, the 74595.c driver routine expects a pointer to the data.
This sample code shows how to call the driver routine if you have
a single byte variable (for just 1 74hc595), or if you have an array
of data (for several 74hc595's).
int8 value;
int8 array[3] = {0x27, 0x45, 0x13};
// How to send a single byte variable to the 74595 driver:
value = 0x55;
write_expanded_outputs(&value);
// How to send an array to the 74595 driver:
write_expanded_outputs(array);
OpenSys
Posted: Wed Oct 27, 2010 6:32 am |
| PCM programmer wrote: | Here are the connections required by the 74595.c driver:
EXP_OUT_DO DS
EXP_OUT_CLOCK SH_SP
Other signals
+5v /MR
Ground /OE
int8 value;
value = 0x55;
thank you for answer-me.
my pins outs is ok now, i miss the PIN_D2 is set it in error PIN_D3 in ST_CP.
One answer that you don't answer-me is can i use the SDO and CLK at same time for two devices ?
i just put:
value = 0x01;
one led nÂș2 is turn on, but if i change the hex 01 don't have any led on, and in other hex's codes have garbage in lcd, ethernet module dont init, pic reset, etc...
can you show a example of the correct hex codes to 74hc595 ?
Regards,
VS |
