dafneb
| Timer 3's formula for PIC18F |
Posted: Mon Oct 11, 2010 1:22 am |
I'm using a PIC18F4550 and i have a little question here... What's the formula for the Timer 3's charge value?
Thanks.
Hola,
Estoy usando un PIC18F4550 y tengo una pequeña pregunta... ¿Cuál es la formula para el valor de carga del Timer 3?
Gracias. |
Posted: Mon Oct 11, 2010 3:02 am |
The same as for timer1.
It can run off FOSC/4, divided by 1,2,4, or 8, or from the timer1 oscillator (if used).
Only difference is that it can also be connected to the special event triggers from the CCP.
dafneb
Posted: Mon Oct 11, 2010 6:31 am |
Thanks a lot!  |
