Orcino
| PIC16f630 error in interrupt with serial (SOLVED) |
Posted: Tue Oct 12, 2010 11:37 am |
I fogot put #int_TIMER1 in function.
Hi ever body.
In the code below when I enable interrupt TIMER1 the program enters an infinite loop. But it works ok without interruption.
Can anyone help?
Thanks in advance.
| Code: | #include <16F630.h>
#FUSES NOWDT // No Watch Dog Timer
#FUSES HS // High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPROTECT // Code not protected from reading
#FUSES NOBROWNOUT // No brownout reset
#FUSES MCLR // Master Clear pin enabled
#FUSES NOCPD // No EE protection
#FUSES PUT // Power Up Timer
#use rs232(baud=9600,parity=N,xmit=PIN_A2,rcv=PIN_C0,bits=8, ERRORS)
#define RL_TX1 PIN_C3
#define RL_TX2 PIN_A0
// Funções
void acionaRlTX1(void);
void acionaRlTX2(void);
void desligaReles(void);
// Variaveis globais
int8 contTempo=0,
segundos=0;
char x=0;
int1 flagTempoOver=0,
flagTX1=0,
flagTX2=0;
void TIMER1_isr(void)
contTempo++;
if(contTempo==10)
segundos++;
contTempo=0;
if(segundos==15)
flagTempoOver=1;
setup_comparator(NC_NC);
disable_interrupts(INT_TIMER1);
disable_interrupts(GLOBAL);
if(kbhit())
x = getc();
if (x=='A')
acionaRlTX1();
segundos=0;
if( x=='B')
acionaRlTX2();
segundos=0;
if(flagTempoOver)
desligaReles();
if(!flagTX1 && !flagTX2)
clear_interrupt(int_timer1);
output_high(RL_TX1);
flagTX1=1;
output_high(RL_TX2);
flagTX2=1;
// Desliga os reles e reinicia todas as variaveis
output_low(RL_TX1);
output_low(RL_TX2);
flagTX1=0;
flagTX2=0;
flagTempoOver=0;
