andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
| CCS SD/MMC driver MBR support |
Posted: Fri Aug 20, 2010 3:24 am |
I know there's quite a few people using this driver because it's bundled with the compiler. It may not be the best, but the price is hard to beat!
One of its shortcomings is that it doesn't handle cards with a Master Boot Record. Naturally, every single SD card I had on hand had an MBR! Support for the MBR is relatively trivial to implement, so I thought I'd post how. This involves the "mmcsd.c" CCS driver file with "Copyright 2007" in the header comments. Make a backup copy of it before starting to edit it, just in case.
Search for: | Code: | | uint32_t g_mmcsdBufferAddress; | and add under it: | Code: | | uint32_t g_mmcsdPartitionOffset; |
Next, just before the "mmcsd_init" function add a new function: | Code: | void mmcsd_check_part(uint16_t off)
if (g_mmcsd_buffer[off + 0] == 0x80)
// active partition
uint8_t t;
t = g_mmcsd_buffer[off + 4];
if (t == 0x04 || t == 0x06 || t == 0x0B)
// FAT16 or FAT32 partition
g_mmcsdPartitionOffset = make32(
g_mmcsd_buffer[off + 11], g_mmcsd_buffer[off + 10],
g_mmcsd_buffer[off + 9], g_mmcsd_buffer[off + 8]) * MMCSD_MAX_BLOCK_SIZE;
In the "mmcsd_init" function, right after the line: | Code: | | r1 = mmcsd_load_buffer(); | Add the lines: | Code: | g_mmcsdPartitionOffset = 0;
mmcsd_check_part(0x1EE);
mmcsd_check_part(0x1DE);
mmcsd_check_part(0x1CE);
mmcsd_check_part(0x1BE); |
Finally, in the function "mmcsd_move_buffer", after the line: | Code: | | new_block = new_addr - (new_addr % MMCSD_MAX_BLOCK_SIZE); | Add the line: | Code: | | new_block += g_mmcsdPartitionOffset; |
This doesn't do anything about FAT16 vs FAT32 or SD vs SDHC. If only dynamic runtime support for all those was as easy! _________________ Andrew
ryanmurray9
| altering sd mbr partition table |
Posted: Fri Oct 01, 2010 12:21 pm |
| How could I use the mmcsd.c file to alter my MBR to make the sd card bootable? I am new to the forum, so if I am asking this in the wrong place, the could you direct me to where I should be asking? |
andrewg
Posted: Sat Oct 02, 2010 7:28 am |
You would need to understand how your chosen operating system makes a bootable SD card. Use a "sector editor" (Google that) to examine the disk structure.
In general, though, the MBR must have a boot program written into it. Sometimes the disk must be partitioned such that there is a chunk of unpartitioned space after the MBR and before the first partition that is used to store the boot program. Sometimes boot programs are stored as regular files on one of the partitions. The boot sector of each partition can also have executable code.
It's all really quite complicated, plus it will require quite a bit of code and data storage for all the boot software so you can write it to the card. IMO, making an SD bootable is a job best done by a PC, not a microcontroller. _________________ Andrew |
