CCS project problem
soulraven
View user's profile Send private message Send e-mail Yahoo Messenger
CCS project problem
PostPosted: Fri Aug 27, 2010 10:12 pm     Reply with quote
I tried to keep an older project, "computer" from board Dacia 1310, only want to add to an identification with iButton using 1wire.
So far all well and good, I did a part of the project, only that I was stuck on some code issues, mention that I'm not very good at programming and C, but as I thought Iara project so far and what I to realize.
- Driver to get in the car, the key is hanging a iButton tag, the engine is stopped. The driver connects iButton tag for a few seconds to be identified for special plug, this time leaving a 1logic.
- The driver starts the car and go.
- If the car is started before your iButton to be identified, then exit left 0logic.
- If the site is iButton identified, but not for five minutes to start the engine, passes out on 0logic.
What I fail to at the moment and I do not know, is how to count timer command 600 seconds and simultaneously verify if the tag is checked or not, the remaining software functions I've done, but I blocked the implementation of the above.
Can you help? I attached the draft scheme Proteus including source code.
Even give me advice or help me and I see my dream come true, then comes the fun of programming and performance wiring.
http://www.dump.ro/fisiere/ibutton-zip/217920/VzGopETJrhKH81p5
sorry for my bad english
PostPosted: Sat Aug 28, 2010 3:57 pm     Reply with quote
command 600 seconds and simultaneously verify if the tag is checked or not.
See this thread on multi-tasking techniques in a PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=17189
If that requires too much of a re-write, and you don't want to do it,
then look at my example in the middle of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=40578
It shows how to break up a large delay into a loop that does many
small delays. Then you poll your device once every pass through the loop.
This method might be faster for your to implement.
