WDT not working
Goto page 1, 2  Next
maaply
WDT not working
PostPosted: Tue Mar 23, 2010 6:57 pm     Reply with quote
I implemented WDT in my code. It is not working. Someone can help me to find, what I am doing wrong? My code is below,
#include <16F723.h>
#device adc = 8
#FUSES WDT      /*  Watch Dog Timer */
#FUSES INTRC_IO   /* Internal RC Osc, no CLKOUT */
#FUSES PUT        /* Power Up Timer */
#FUSES MCLR       /* Master Clear pin enabled */
#FUSES NOPROTECT  /* Code not protected from reading */
#FUSES BROWNOUT /* Reset when brownout detected */
#FUSES BORV25   /* Brownout reset at 2.5V */
#FUSES PLLEN
#FUSES NODEBUG    /* No Debug mode for ICD */
#FUSES NOVCAP
#use delay(clock=2000000, PLLEN)
setup_wdt(WDT_2304MS);
output_a = 0xFF;
output_a=0x00;
while();
I should get LED blink connected on port A, but its not blinking !
In debugger code rotating in while loop?
What's wrong in this code ?
Please help me.
maaply
robomaniac
PostPosted: Tue Mar 23, 2010 8:07 pm     Reply with quote
output_a = 0xFF;
output_a=0x00;
while();
That will make the LED blink once since the while is blocking. I guest you want to see the LED blink all the time because the WDT is doing it job.
First thing first. Port A is in Input per default so you have to
// Constants used for SETUP_ADC() are:
#define ADC_OFF                0              // ADC Off
SETUP_ADC(ADC_OFF );
SETUP_ADC_PORTS(NO_ANALOGS);
Then you could use those build in CCS function like
#define GREEN_LED   PIN_A2
output_high(GREEN_LED);
output_low(GREEN_LED);
First thing I would test if you can blink/light up a LED on portB or portC.
That will ensure you that the delay is really 1000ms.
When that works try on portA. When that works, implement the WDT.
good luck
Jérôme Demers
www.jeromedemers.com
maaply
PostPosted: Tue Mar 23, 2010 9:54 pm     Reply with quote
Thanks Robomaniac,
I tried with PORT B and PORT D also, but not working. My code is below.
#include <16F727.h>
#device adc=8
#FUSES WDT                      //Watch Dog Timer
//#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BROWNOUT_NOSL            //Brownout enabled during operation, disabled during SLEEP
#FUSES BORV19
#FUSES PLLEN
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOVCAP
#use delay(clock=2000000,PLLEN)
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
   // TODO: USER CODE!!
set_tris_b(0x00 );
output_b(0x00);
output_b(0xff);
This code was generated by CCS project wizard.
Thanks.
maaply
robomaniac
PostPosted: Tue Mar 23, 2010 11:07 pm     Reply with quote
When you use
set_tris_b(0x00 );
you need
#use fast_io(B)
http://www.ccsinfo.com/downloads/PCDReferenceManual.pdf
page 155 of PDF
This directive affects how the compiler will generate code for input and output
instructions that follow. This directive takes effect until another #use xxx_IO
directive is encountered. The fixed method of doing I/O will cause the compiler
to generate code to make an I/O pin either input or output every time it is used.
The pins are programmed according to the information in this directive (not the
operations actually performed). This saves a byte of RAM used in standard I/O.
When linking multiple compilation units be aware this directive only applies to
the current compilation unit.
When you use fast IO, you need to tell the compiler that A1 is Input and B3 is output, etc. Normally CCS can handle all that without telling him.
But that is just for info and probably will not make your code work.
try this code, it is working right now on my breadboard!
Change the include to 16F727
#include <16lf722.h>
#fuses INTRC_IO,NOWDT
#use delay(INTERNAL=8Mhz)
#define GREEN_LED   PIN_C2
   while(true)
           output_toggle(GREEN_LED);
Try to make your PIC work in the first place.
I will try the WTD right now Smile never coded that yet!
Jérôme Demers
robomaniac
PostPosted: Tue Mar 23, 2010 11:22 pm     Reply with quote
Got the Watch dog working!!
#fuses INTRC_IO
   while(true);
So you remove the line saying "#FUSES WDT" and it does not blink anymore!
Nice!
Jérôme Demers
maaply
PostPosted: Tue Mar 23, 2010 11:54 pm     Reply with quote
Dear Robomaniac,
Yes have that line. refer my code, #fuses wdt is there in first line. I tried your code with PIC16F727, NOT working.
Thanks,
maaply
robomaniac
PostPosted: Wed Mar 24, 2010 12:01 am     Reply with quote
I was just saying remove #fuses to prove to myself that the WDT was working. I was not refering at your code and telling you what to do.
so if it is not working... hardware problems? Got the cathode to ground and anode to pin of PIC?
Can you make a LED blink with your hardware?
Jérôme Demers
maaply
PostPosted: Wed Mar 24, 2010 12:08 am     Reply with quote
Yes I can blink LED, without WDT. Just with some delay,
   output_a(0xFF);
   output_a(0x00);
So the problem is start on WDT. I interfaced some other HW using SPI, I2C, UART without any problem.
When I try to implement WDT, there is no effect.
maaply
robomaniac
PostPosted: Wed Mar 24, 2010 12:14 am     Reply with quote
Ok then try something very small for the WTD timer:
like setup_wdt(WDT_18MS);
If that does not work, then there is probably something in the datasheet saying something smart.
Jérôme Demers
maaply
PostPosted: Wed Mar 24, 2010 12:52 am     Reply with quote
Yes, I tried all the values given in device.h file.
#define WDT_18MS        8
#define WDT_36MS        9
#define WDT_72MS       10
#define WDT_144MS      11
#define WDT_288MS      12
#define WDT_576MS      13
#define WDT_1152MS     14
#define WDT_2304MS     15
Nothing is made it work.
Thanks.
maaply
PostPosted: Wed Mar 24, 2010 12:54 pm     Reply with quote
Post your compiler version. It's a 4-digit number in this format: x.xxx
It's given at the top of the .LST file, which will be in your project
directory after a successful compilation.
maaply
PostPosted: Wed Mar 24, 2010 6:37 pm     Reply with quote
CS PCM C Compiler, Version 4.082, 45061 24-Mar-10 14:54
maaply
PostPosted: Thu Mar 25, 2010 9:52 pm     Reply with quote
Compiler vs. 4.082 is buggy in the startup code for the internal oscillator.
Also, the setup_oscillator() function is buggy in that version. Try the
program shown below, which uses a substitute routine, called
my_setup_oscillator(). It should setup the internal oscillator to 8 MHz
correctly. It should also do a 2 second WDT timeout period.
I don't have a 16F727 to test this in hardware, but I think it should work.
#include <16F727.h>
#fuses INTRC_IO, PLLEN, WDT
#use delay(clock=8000000)
#byte OSCCON = 0x90
#define my_setup_oscillator(x) OSCCON=x
my_setup_oscillator(OSC_8MHZ);
output_high(PIN_C2);
output_low(PIN_C2);
maaply
PostPosted: Sun Mar 28, 2010 7:52 pm     Reply with quote
Thanks PCM programmer,
my internal oscillator works fine with the above setting.
I tried your code. its not working.
maaply
maaply
PostPosted: Sun Mar 28, 2010 8:01 pm     Reply with quote
Dear all,
I tried to set WDT in " configuration bit " menu in mplab IDE. I enable the WDT. ( by selecting WDT - ON ). almost out all the code is working.
Ok. if i want to enable WDT, by direct Register method. which reg i wand to modify ?
Please help me.
Thanks,
[/b]
maaply
Goto page 1, 2  Next
Page 1 of 2
