liche Guest
| set_tris questions |
Posted: Fri Apr 25, 2003 7:42 pm |
I'm a bit confused on when to use the set_tris statements for various type of i/o configurations such as Standard IO, Fast IO, etc...
Is it necessary to use the set_tris statements for all of these types of I/O or only on some types?
___________________________
Original Post ID: 14003 |
david smith Guest
| Re: set_tris questions |
Posted: Sat Apr 26, 2003 5:06 pm |
:=I'm a bit confused on when to use the set_tris statements for various type of i/o configurations such as Standard IO, Fast IO, etc...
Somebody may offer better info, but I believe...
STANDARD_IO (default) doesn't require SET_TRIS, and sets direction each instance of an IO cmd.
I use FAST_IO and Set_TRIS on projects to run faster and with less RAM.
On most of my projects, the use of the pin never changes.
In a current project, I use PORTB as a bidirection bus to external parallel registers, so I've defined constants for
bus direction.
Example:
#USE FAST_IO(B) // Use TRIS fctns to set dir of I/O
// Data bus is B, and is bidirectional
#BYTE BUS_RD = 0xFF // tris register values for reading
#BYTE BUS_WR = 0x00 // for writing
//*** write to bus routine
int8U wr_ext(int8U addr, int8U data) {
// not shown: set address
SET_TRIS_B(BUS_WR); // set bus direction
PORTB = data; // put data on data bus [B]
WR = 1; // generate wr pulse
WR = 0;
SET_TRIS_B(BUS_RD); // set bus direction
Original Post ID: 14015 |
