Diego Guzman Guest
| 12c508a problem |
Posted: Wed Apr 23, 2003 9:39 am |
Hi, im working for first time with pic12c508a, and i have a problem setting the internal clock, it doesnt work, i put the direcitives of __config _IntRC_OSC and then put 0xff in the oscal register to have the highest frequency, and doesnt work.
I need to generate a square singal of 700khz, so i need help to setup the internal clock at 4Mhz.
I read that the directive #rom 0x000 = {0x0025} works, thats ok??
Diego
___________________________
Original Post ID: 13944 |
| Re: 12c508a problem |
Posted: Wed Apr 23, 2003 11:45 am |
:=Hi, im working for first time with pic12c508a, and i have a problem setting the internal clock, it doesnt work, i put the direcitives of __config _IntRC_OSC and then put 0xff in the oscal register to have the highest frequency, and doesnt work.
CCS does not use the __config directive. CCS uses the #fuses
directive. This is in the manual.
See this example program, which shows how to use the #fuses
statement:
<a href="http://www.cc.puv.fi/~t0101190/projekti/source/Examples/ex_8pin.c" TARGET="_blank">http://www.cc.puv.fi/~t0101190/projekti/source/Examples/ex_8pin.c</a>
Original Post ID: 13947 |
Diego Guzman Guest
Posted: Thu Apr 24, 2003 9:30 am |
I'm confused because i´m working with both assembler and ccs, because both of them doesnt work. In the ccs using the #fuse directive, and define the I/O lines, using the next code:
#include <12C508A.h>
#fuses NOWDT, NOPROTECT, INTRC, MCLR
#use fast_io(B)
#byte portb = 0x06
#bit rec = 0x06.4
#bit tri = 0x06.0
#bit emi = 0x06.2
#use delay(clock = 4000000)
#rom 0x000 = {0x0025} ; this directive i use because i read
with this the internal rc works but
it doesnt
inicializar (){
portb = 0x00;
set_tris_b(0b00011000);
inicializar();
portb = 0x00;
while (TRUE){
if(rec==0){
tri = 0;
emi = 1;
delay_ms(0.7);
emi = 0;
delay_ms(0.7);
else tri = 1;
i dont know what is wrong here, could you help me..
Original Post ID: 13974 |
R.J.Hamlett Guest
Posted: Thu Apr 24, 2003 10:50 am |
:=I'm confused because i´m working with both assembler and ccs, because both of them doesnt work. In the ccs using the #fuse directive, and define the I/O lines, using the next code:
:=#include <12C508A.h>
:=#fuses NOWDT, NOPROTECT, INTRC, MCLR
With MCLR selected, you must ensure that pin 4 has a pull-up. Is this true?.
:=#use fast_io(B)
:=#byte portb = 0x06
:=#bit rec = 0x06.4
:=#bit tri = 0x06.0
:=#bit emi = 0x06.2
:=#use delay(clock = 4000000)
:=#rom 0x000 = {0x0025} ; this directive i use because i read
:= with this the internal rc works but
:= it doesnt
You do not need this. If you select the RC oscillator, the compiler automatically inserts a MOVWF 05 instruction at the start of memory.
:=inicializar (){
:= portb = 0x00;
:= set_tris_b(0b00011000);
:=void main() {
:= inicializar();
:= portb = 0x00;
:= while (TRUE){
:= if(rec==0){
:= tri = 0;
:= emi = 1;
:= delay_ms(0.7);
You cannot have floating point delays. If you want a 0.7mSec delay, use delay_us(700);
:= emi = 0;
:= delay_ms(0.7);
:= else tri = 1;
:=i dont know what is wrong here, could you help me..
I suspect the main fault, is the use of a floating point value on the delay.
Original Post ID: 13977 |
Diego Guzman Guest
Posted: Sat Apr 26, 2003 10:22 am |
Thank you R.J.Hamlett, i'm gone a try your tips, i only need to buy more 12c508a
Original Post ID: 14011 |
Felix Althaus
Joined: 09 Sep 2003 Posts: 67 Location: Winterthur, Switzerland
Posted: Sat Apr 26, 2003 12:50 pm |
:=Thank you R.J.Hamlett, i'm gone a try your tips, i only need to buy more 12c508a
What about using a -JW part with eprom and window to erase this with UV light (if they exist for 12c508)?
So you only need one part for experimenting (ok, it will cost more)
mfg
Felix
Original Post ID: 14013 |
