mmc01
| How to use TPA81 Thermopile Array with PIC16F877 |
Posted: Tue Jul 20, 2010 2:49 pm |
I want to use TPA81 Thermopile Array with PIC16F877 but I don't know how to use, and in data sheet not have more data for use. If you have simple code for read data from TPA81 Thermopile Array and send to serial port for show data. Please help me. |
Posted: Tue Jul 20, 2010 3:03 pm |
Look at the webpages of the online sellers. They have tons of sample
code for the TPA81. It might not be in CCS, but it's close enough.
Look at the .Zip file at the bottom of this page:
http://www.robot-electronics.co.uk/htm/thermabot.htm
It has a getTemperature() function that reads the temperature from
the TPA81. Just translate it to CCS. Change i2c_tx() to i2c_write().
Change i2c_rx() to i2c_read(). Keep the same parameters as in
their code. You will also need to use their global array, temperature[].
Keep that same declaration of it. Add the normal framework for a
CCS program, with the #use i2c() line, and that gives the basic code
that you need. |
xbach
Posted: Wed Jul 21, 2010 6:43 am |
Hi, maybe.. | Code: | //*********************************************************************//
// P2P_TPA81.c (PICDEM(tm)2 PLUS DEMO BOARD) //
// Funktion: lest 8 (9) Temperaturwerte des Devantech TPA81 //
// Thermopilesensors und setzt das Servo. //
// Pinbelegung TPA81 : +------------+ //
// gr +5V --|o | //
// li SDA --|o | //
// bl SCL --|o TPA81 | //
// nc |o | //
// gn Gnd --|o | //
// Pulse--|o | //
// Servo +5V--|o | //
// GnD--|o | //
// Bach 30.04.2009 //
//#include <18F4520.h>
//#fuses INTRC_IO,NOWDT,NOPROTECT
//#use delay(clock=8000000)
#include <16F877A.h>
#fuses XT,NOWDT,NOPROTECT
#use i2c(master, SCL=PIN_C3, SDA=PIN_C4)
#include <_lcd_p2p.c>
byte TPA81_ID = 0xD0; // Standardadresse I2C für TPA81
byte t[10], i, servo;
// liefert die Temperatur in t[] array und
// Firmwareversion in t[0]
void read_tpa81( byte slaveID ) {
for ( i=0; i<10; i++) {
i2c_start();
i2c_write(slaveID);
i2c_write(i); // Leseregister
i2c_start();
i2c_write(slaveID+1);
t[i] = i2c_read(0);
i2c_stop ();
delay_ms(10);
// setzt Servoposition 0..32
void set_servo_tpa81 ( byte slaveID, byte servo_pos ) {
i2c_start();
i2c_write(slaveID);
i2c_write(0);
i2c_write(servo_pos&0x1F); // 0.. 31
i2c_stop ();
lcd_init();
printf(lcd_putc,"\f PICdem2 Plus ");
printf(lcd_putc,"\n (c)Bach09");
delay_ms(2000);
// ......... 1234567890123456 ......
printf(lcd_putc,"\f* Sensor TPA81 *\n");
read_tpa81( TPA81_ID );
printf(lcd_putc,"Firmware V.1.%u", t[0]);
servo=0;
while (1) {
if (!input(PIN_A4)) servo += 3;
printf (lcd_putc,"\f%u %u %u %u\n", t[1], t[2], t[3], t[4]);
printf (lcd_putc,"%u %u %u %u", t[5], t[6], t[7], t[8]);
set_servo_tpa81 ( TPA81_ID, servo );
while (!input(PIN_B0)) printf(lcd_putc,"\f ServoPos %u",servo);
mmc01
Posted: Wed Jul 21, 2010 7:18 pm |
I use this code and it show
255 255 255 255
255 255 255 255 only. I can't read data from tpa81. please help me.
| Code: | #include <16F877A.h>
#use rs232(BAUD=9600,xmit=PIN_C6,rcv=PIN_C7)
byte TPA81_ID = 0xD0; // Standardadresse I2C f?r TPA81
i2c_start();
i2c_write(slaveID);
i2c_start();
t[i] = i2c_read(0);
i2c_stop ();
delay_ms(10);
i2c_start();
i2c_write(slaveID);
i2c_write(0);
i2c_stop ();
printf("\f PICdem2 Plus ");
printf("\n (c)Bach09");
delay_ms(2000);
printf("\f* Sensor TPA81 *\n");
printf("Firmware V.1.%u", t[0]);
servo=0;
while (1) {
printf ("\f%u %u %u %u\n", t[1], t[2], t[3], t[4]);
printf ("%u %u %u %u", t[5], t[6], t[7], t[8]);
while (!input(PIN_B0)) printf("\f ServoPos %u",servo);
Posted: Wed Jul 21, 2010 7:39 pm |
Do have 4.7K pull-up resistors on the SDA and SCL lines ?
One reason for getting 0xFF is if you forget to put the pull-ups on.
They are part of the i2c specification. |
