| joergn
				| 18F45K22 ECCP unit problem |
				|  Posted: Mon Jul 19, 2010 11:35 am |   |
				| Hi, does anybody tried the 18F45K22 ?
 I am using the internal osc with PLL to obtain a 64Mhz clock without external resonator but my mute is meanwhile low, because I still have not managed to bring the ECCP unit in operation.......
 I have PWM experience with the 18F4431, which has power PWM and a CCP
 unit, so the setup_CCPx commands and set_pwm_dutyx();  I tried in the same way but no success so far.
 I have the latest 4.109 compiler update.
 The 18F45K22 has 5 CCPs which can be operated with 3 different timers,
 or all at the same timer 2.
 When I am trying to use the SETUP_CCPx command the CCP1 and
 CCP2 compiles but SETUP_CCP3 leads to an error:
 *** Error 12 "main.c" Line 83(15,16): Undefined identifier  -- SETUP_CCP3
 1 Errors,  0 Warnings.
 After no succes with the inbuilt functions I tried it with the SFRs directly
 like it was posted in the forum with a 18F8722.
 My code is at the moment:
  	  | Code: |  	  | #include <18F45K22.h> #device ICD=TRUE
 #device adc=10
 #FUSES NOWDT                    //No Watch Dog Timer
 #FUSES INTRC_IO                   // this is the internal OSC active
 #FUSES NOPROTECT
 #FUSES NOEBTRB
 #FUSES NOEBTR
 //#FUSES NOXINST
 #FUSES NODELAYINTOSC
 #FUSES NOWRTC
 #use delay(clock=64Mhz )    // setting the high f works just here ;-)
 #use rs232(baud=38400,xmit=PIN_C6 ,rcv=PIN_C7 , parity=N,bits=8)
  	  | Code: |  	  | #include <main.h>
 // Define of PIN layout///////////////////////////////////
 #define BATD 0             // AN0
 #define TEMPERATUR 8       // AN8 ; ist jetzt digital configuriert
 #define LED1 PIN_D4
 #define RESERVE1 PIN_D0
 #define RESERVE3 PIN_C5
 #define MAXLOOPS 20;
 //#define SELECT TRUE;
 // MCU specific register definitions
 #define PR2 0xFBB           // Timer2 Period Register
 #define PR4 0xF52           // Timer4 Period Register
 #define PR6 0xF4B          // Timer6 Period Register
 #define CCPR1L 0xFBE        // Capture/Compare/PWM Register 1, Low Byte
 #define CCPR1H 0xFBF        // Capture/Compare/PWM Register 1, High Byte
 #define CCPR2L 0xF67        // Capture/Compare/PWM Register 1, Low Byte
 #define CCPR2H 0xF68        // Capture/Compare/PWM Register 1, High Byte
 #define CCPR3L 0xF5E        // Capture/Compare/PWM Register 1, Low Byte
 #define CCPR3H 0xF5F        // Capture/Compare/PWM Register 1, High Byte
 #define PWM1CON 0xFB7       // PWM Dead-Band Delay register,
 #define PWM2CON 0xF65       // PWM Dead-Band Delay register,
 #define PWM3CON 0xF5C       // PWM Dead-Band Delay register,
 #define CONFIG3H 0x300005   // MCLRE — P2BMX T3CMX HFOFST CCP3MX PBADEN CCP2MX "1011 1111"
 #define TRISA 0xF92
 #define TRISB 0xF93
 #define TRISC 0xF94
 #define TRISD 0xF95
 #define TRISE 0xF96
 #define CCP1CON 0xFBD      // CCPx PIN CONFIGURATION CCP PRESCALER setting
 #define CCP3CON 0xF5D
 #define ECCP1 CCP1CON
 #define ECCP1AS 0xFB6      // ENHANCED PWM AUTO-SHUTDOWN
 #define ECCP3AS 0xF5B
 #define CCPTMRS0 0xF49       // PWM TIMER SELECTION CONTROL REGISTER 0
 #define CCPTMRS1 0xF48       // PWM TIMER SELECTION CONTROL REGISTER 1
 void Initmcu(void)
 setup_timer_0(T0_INTERNAL|T0_DIV_16);
 setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_4 );
 setup_timer_2 ( T2_DIV_BY_1, 50, 1); // (mode, period, postscale)   used by default as CCPx PWM base
 setup_timer_3(T3_INTERNAL|T3_DIV_BY_2);
 setup_timer_4 ( T4_DIV_BY_4, 0xc0, 2);
 setup_timer_5 (T5_INTERNAL | T5_DIV_BY_2);
 setup_timer_6 ( T6_DIV_BY_4, 0xc0, 2);
 *TRISC = 0x00; //Set Port C to outputs.  CCP1 and CCP2 are on PortC
 *TRISE = 0x00; //Set Port E to outputs.  CCP3 A and B are on PortE
 //output_low(PIN_E0);
 //output_low(PIN_E1);
 //output_low(PIN_C2);
 *CCPTMRS0 = 0x00; // all ECCP1,2,3 are operated with Timer2
 //SETUP_CCP1(CCP_PWM);
 *CCP1CON = 0x0E;
 *CCP3CON = 0x0E;
 //SETUP_CCP3(CCP_PWM|CCP_PWM_HALF_BRIDGE|CCP_PWM_H_H);
 *PR2 = 24; //Period = 4 * Tosc *(PR2+1) * TMR2Prescaler
 //set_pwm1_duty(31);
 //set_pwm3_duty(31);
 //*PWM1CON = 0x03;
 //*PWM3CON = 0x03;
 *CCPR3L = 0x0C;   // Duty cycle CCP3
 *CCPR1L = 0x0C;
 *ECCP1AS = 0x00;
 *ECCP3AS = 0x00;
 long mscounter;
 long dutyc3;
 mscounter=0;
 dutyc3=230;
 //setup_adc (ADC_CLOCK_DIV_64);
 //setup_adc_ports( ALL_ANALOG|VSS_VDD );
 Initmcu();
 while(true)
 //mscounter++;
 //output_toggle(LED1);
 //if(mscounter ==0)
 output_high(RESERVE3);
 delay_cycles(100);
 //delay_us(1);
 output_low(RESERVE3);
 delay_us(1);
 hoping for some hints and best Regards
 Hi I meanwhile tracked down the reason: timer2 is not running after the setup_timer_2 command.
 So after turning on by SFR programming: *T2CON = 0x05;
 it worx.
 It seems as if the chip is not yet supported with all the commands.
  	  | Code: |  	  | void Initmcu(void) {
 delay_ms(10);
 setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1 );
 //setup_timer_2 ( T2_DIV_BY_1,127, 1 ); // (mode, period, postscale)   used by default as CCPx PWM base
 *T2CON = 0x05;  // activates timer2 directly !!!!!!
 //set_timer2(0);
 setup_timer_3 (T3_DIV_BY_2);
 *CCP1CON = 0x0E;
 *CCP3CON = 0b10001100;    //
 *PR2 = 80; //Period = 4 * Tosc *(PR2+1) * TMR2Prescaler 50kHz
 //*PWM1CON = 0x03;
 *PWM3CON = 0x03;
 *CCPR3L = 40;   // Duty cycle CCP3 50%
 *CCPR1L = 0x0C;   // Duty cycle CCP1
 *ECCP1AS = 0x00;
 *ECCP3AS = 0x05;
 //output_high(PIN_E0);
 //output_high(PIN_E1);
 ;-O
