tomay3000
| PIC16F628A : Just take a look |
Posted: Sun Jul 11, 2010 7:24 pm |
I made an RS232 Serial External SPI FLASH Programmer for Winbond EEPROMs series. & the only function that works great is just reading
So can anyone help me to solve my problems
This is my PIC16F628A driver code for Winbond W25Xxx W25Xxx.C:
| Code: | ///////////////////////////////////////////////////////////////////////////
//// Library for a Winbond W25Xxx (128 KB --> 16 MB) ////
//// init_ext_eeprom(); Call before the other functions are used ////
//// write_ext_eeprom(a, d); Write the byte d to the address a ////
//// d = read_ext_eeprom(a); Read the byte d from the address a ////
//// b = ext_eeprom_ready(); Returns TRUE if the eeprom is ready ////
//// to receive opcodes ////
//// The main program may define EEPROM_SELECT, EEPROM_DI, EEPROM_DO ////
//// and EEPROM_CLK to override the defaults below. ////
//// Pin Layout ////
//// | __ | ////
//// | 1: CS EEPROM_SELECT | 8: VCC +5V | ////
//// | | ____ | ////
//// | 2: DO EEPROM_DO | 7: HOLD +5V | ////
//// | __ | | ////
//// | 3: WP +5V | 6: CLK EEPROM_CLK | ////
//// | 4: GND Ground | 5: DIO EEPROM_DI | ////
//// (C) Copyright 1996, 2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
#ifndef EEPROM_SELECT
#define EEPROM_SELECT PIN_A0
#define EEPROM_CLK PIN_A1
#define EEPROM_DI PIN_A2
#define EEPROM_DO PIN_A2
#define EEPROM_ADDRESS int32
void init_ext_eeprom()
output_high(EEPROM_SELECT);
output_low(EEPROM_DI);
output_low(EEPROM_CLK);
BOOLEAN ext_eeprom_ready()
BYTE rdsr, i, data;
rdsr = 0x05; // rdsr opcode
output_low(EEPROM_SELECT);
for(i=0; i<8; ++i)
output_bit(EEPROM_DI, shift_left(&rdsr, 1, 0));
output_high(EEPROM_CLK); // data latches
output_low(EEPROM_CLK); // back to idle
for(i=0; i<8; ++i)
shift_left(&data, 1, input(EEPROM_DO));
output_low(EEPROM_CLK); // data latches & back to idle
return !bit_test(data, 0);
void erase_ext_eeprom()
BYTE i, wren, erase;
wren = 0x06; // wren opcode
erase = 0xc7; // chip erase
// Wait until the eeprom is done with a previous write
while(!ext_eeprom_ready());
for(i=0; i<8; ++i)
output_bit(EEPROM_DI, shift_left(&wren, 1, 0));
for(i=0; i<8; ++i)
output_bit(EEPROM_DI, shift_left(&erase, 1, 0));
delay_ms(40000); // tCE
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data)
BYTE cmd[5], i, wren;
cmd[0] = data;
cmd[1] = (BYTE) address;
cmd[2] = (BYTE) (address >> 8);
cmd[3] = (BYTE) (address >> 16);
cmd[4] = 0x02;
for(i=0; i<8; ++i)
for(i=0; i<40; ++i)
output_bit(EEPROM_DI, shift_left(cmd, 5, 0));
delay_ms(3); // tPP
BYTE read_ext_eeprom(EEPROM_ADDRESS address)
BYTE cmd[4], i, data;
cmd[0] = (BYTE) address;
cmd[1] = (BYTE) (address >> 8);
cmd[2] = (BYTE) (address >> 16);
cmd[3] = 0x03;
for(i=0; i<32; ++i)
output_bit(EEPROM_DI, shift_left(cmd, 4, 0));
for(i=0; i<8; ++i)
return(data);
and Winbond W25Xxx SPI Flash Programmer.h file:
| Code: | #include <16F628A.h>
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PUT //Power Up Timer
#use rs232(baud=115200,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8) |
and the main program is Winbond W25Xxx SPI Flash Programmer.c:
| Code: | #include "Winbond W25Xxx SPI Flash Programmer.h"
#include "W25Xxx.C"
#include <stdio.h>
BYTE cmd[5], co = 0, data = 'X';
int32 address;
#int_TBE
void TBE_isr(void)
disable_interrupts(INT_TBE);
switch(cmd[0])
case 'E':
putc('S');
case 'W':
putc('S');
case 'R':
putc(data);
enable_interrupts(INT_RDA);
#int_RDA
void RDA_isr(void)
cmd[co ++] = getc();
if(co == 5)
disable_interrupts(INT_RDA);
co = 0;
address = ((int32) cmd[1]) << 16;
address |= ((int32) cmd[2]) << 8;
address |= (int32) cmd[3];
switch(cmd[0])
case 'E':
erase_ext_eeprom();
case 'W':
write_ext_eeprom(address, cmd[4]);
case 'R':
data = read_ext_eeprom(address);
enable_interrupts(INT_TBE);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_vref(FALSE);
init_ext_eeprom();
//TODO: User Code
while(TRUE);
So where could the problem be
Thank you any way ;) _________________ PIC16F628A |
Posted: Sun Jul 11, 2010 11:43 pm |
Post the full part number of the eeprom that you're testing, and post a
link to the eeprom data sheet, and post your compiler version.
I suggest simplifying the program. Get rid of the #int_rda and #int_tbe
routines until you get the eeprom working reliably.
Also, your posted code looks like it's a CCS driver, but I don't find any
such driver in the CCS directories. I don't find it if I search the net with
Google. So I could be wrong, but I think you've created an invention
and tacked the CCS copyright message on it. |
tomay3000
Posted: Mon Jul 12, 2010 8:26 am |
| PCM programmer wrote: | Post the full part number of the eeprom that you're testing, and post a
Sorry for my previous post
& for the full part number of my SPI EEPROM is : W25X40A
& a link to its datasheet is : http://www.winbond.com.tw/NR/rdonlyres/93A5FE5A-EEF2-417B-87A8-CB8144F6120D/0/W25X10A_W25X20A_W25X40A_W25X80A.pdf
& my compiler version is : 4.106
& for the W25Xxx.C driver, I crated it using the athor drivers samples.
& I did this test program test.h:
& the test.c main program is :
| Code: | #include "test.h"
#include <stdio.h>
setup_vref(FALSE);
//TODO: User Code
putc(getc());
& I always receive what I sent to the PIC. So it is working
This is an image of my EEPROM Programmer :
http://www.wuala.com/tomay3000/Documents/Electronics/EEPROM%20Programmer.JPG
& the JDM Programmer for the PIC :
http://www.wuala.com/tomay3000/Documents/Electronics/JDM%20Programmer.JPG _________________ PIC16F628A
tomay3000
Posted: Wed Jul 14, 2010 11:09 am |
Finally, I found the solution. The problem was in the VCC voltage, so the Winbond SpiFlash supports a range of (2.7 --> 3.6) volts, not 5 volts, so I found that my Winbond W25Xxx SpiFlash is gone with a 5 volts & my PIC16F628A is working great. _________________ PIC16F628A |
