		| Author | Message |
		| tomay3000
				| PIC16F628A : Just take a look |
				|  Posted: Sun Jul 11, 2010 7:24 pm |   |
				| I made an RS232 Serial External SPI FLASH Programmer for Winbond EEPROMs series. & the only function that works great is just reading
 So can anyone help me to solve my problems
 This is my PIC16F628A driver code for Winbond W25Xxx W25Xxx.C:
  	  | Code: |  	  | /////////////////////////////////////////////////////////////////////////// ////   Library for a Winbond W25Xxx (128 KB --> 16 MB)                 ////
 ////   init_ext_eeprom();    Call before the other functions are used  ////
 ////   write_ext_eeprom(a, d);  Write the byte d to the address a      ////
 ////   d = read_ext_eeprom(a);   Read the byte d from the address a    ////
 ////   b = ext_eeprom_ready();  Returns TRUE if the eeprom is ready    ////
 ////                            to receive opcodes                     ////
 ////   The main program may define EEPROM_SELECT, EEPROM_DI, EEPROM_DO ////
 ////   and EEPROM_CLK to override the defaults below.                  ////
 ////                      Pin Layout                                   ////
 ////   |    __                                       |                 ////
 ////   | 1: CS   EEPROM_SELECT | 8: VCC   +5V        |                 ////
 ////   |                       |    ____             |                 ////
 ////   | 2: DO   EEPROM_DO     | 7: HOLD  +5V        |                 ////
 ////   |    __                 |                     |                 ////
 ////   | 3: WP   +5V           | 6: CLK   EEPROM_CLK |                 ////
 ////   | 4: GND  Ground        | 5: DIO   EEPROM_DI  |                 ////
 ////        (C) Copyright 1996, 2003 Custom Computer Services          ////
 //// This source code may only be used by licensed users of the CCS C  ////
 //// compiler.  This source code may only be distributed to other      ////
 //// licensed users of the CCS C compiler.  No other use, reproduction ////
 //// or distribution is permitted without written permission.          ////
 //// Derivative programs created using this software in object code    ////
 //// form are not restricted in any way.                               ////
 #ifndef EEPROM_SELECT
 #define EEPROM_SELECT PIN_A0
 #define EEPROM_CLK    PIN_A1
 #define EEPROM_DI     PIN_A2
 #define EEPROM_DO     PIN_A2
 #define EEPROM_ADDRESS  int32
 void init_ext_eeprom()
 output_high(EEPROM_SELECT);
 output_low(EEPROM_DI);
 output_low(EEPROM_CLK);
 BOOLEAN ext_eeprom_ready()
 BYTE rdsr, i, data;
 rdsr = 0x05;                  // rdsr opcode
 output_low(EEPROM_SELECT);
 for(i=0; i<8; ++i)
 output_bit(EEPROM_DI, shift_left(&rdsr, 1, 0));
 output_high(EEPROM_CLK);   // data latches
 output_low(EEPROM_CLK);    // back to idle
 for(i=0; i<8; ++i)
 shift_left(&data, 1, input(EEPROM_DO));
 output_low(EEPROM_CLK);    // data latches & back to idle
 return !bit_test(data, 0);
 void erase_ext_eeprom()
 BYTE i, wren, erase;
 wren = 0x06;                  // wren opcode
 erase = 0xc7;                 // chip erase
 // Wait until the eeprom is done with a previous write
 while(!ext_eeprom_ready());
 for(i=0; i<8; ++i)
 output_bit(EEPROM_DI, shift_left(&wren, 1, 0));
 for(i=0; i<8; ++i)
 output_bit(EEPROM_DI, shift_left(&erase, 1, 0));
 delay_ms(40000);              // tCE
 void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data)
 BYTE cmd[5], i, wren;
 cmd[0] = data;
 cmd[1] = (BYTE) address;
 cmd[2] = (BYTE) (address >> 8);
 cmd[3] = (BYTE) (address >> 16);
 cmd[4] = 0x02;
 for(i=0; i<8; ++i)
 for(i=0; i<40; ++i)
 output_bit(EEPROM_DI, shift_left(cmd, 5, 0));
 delay_ms(3);                  // tPP
 BYTE read_ext_eeprom(EEPROM_ADDRESS address)
 BYTE cmd[4], i, data;
 cmd[0] = (BYTE) address;
 cmd[1] = (BYTE) (address >> 8);
 cmd[2] = (BYTE) (address >> 16);
 cmd[3] = 0x03;
 for(i=0; i<32; ++i)
 output_bit(EEPROM_DI, shift_left(cmd, 4, 0));
 for(i=0; i<8; ++i)
 return(data);
 and Winbond W25Xxx SPI Flash Programmer.h file:
  	  | Code: |  	  | #include <16F628A.h>
 #FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
 #FUSES PUT                      //Power Up Timer
 #FUSES NOPROTECT                //Code not protected from reading
 #FUSES MCLR                     //Master Clear pin enabled
 #FUSES NOCPD                    //No EE protection
 #use delay(clock=20000000)
 #use rs232(baud=115200,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8)
 and the main program is Winbond W25Xxx SPI Flash Programmer.c:
  	  | Code: |  	  | #include "Winbond W25Xxx SPI Flash Programmer.h" #include "W25Xxx.C"
 #include <stdio.h>
 BYTE cmd[5], co = 0, data = 'X';
 int32 address;
 #int_TBE
 void  TBE_isr(void)
 disable_interrupts(INT_TBE);
 switch(cmd[0])
 case 'E':
 putc('S');
 case 'W':
 putc('S');
 case 'R':
 putc(data);
 enable_interrupts(INT_RDA);
 #int_RDA
 void  RDA_isr(void)
 cmd[co ++] = getc();
 if(co == 5)
 disable_interrupts(INT_RDA);
 co = 0;
 address = ((int32) cmd[1]) << 16;
 address |= ((int32) cmd[2]) << 8;
 address |= (int32) cmd[3];
 switch(cmd[0])
 case 'E':
 erase_ext_eeprom();
 case 'W':
 write_ext_eeprom(address, cmd[4]);
 case 'R':
 data = read_ext_eeprom(address);
 enable_interrupts(INT_TBE);
 setup_timer_1(T1_DISABLED);
 setup_ccp1(CCP_OFF);
 setup_vref(FALSE);
 init_ext_eeprom();
 //TODO: User Code
 while(TRUE);
 So where could the problem be
 Thank you any way ;)
 PIC16F628A
		| PCM programmer
				|  Posted: Sun Jul 11, 2010 11:43 pm |   |
				| Post the full part number of the eeprom that you're testing, and post a link to the eeprom data sheet, and post your compiler version.
 I suggest simplifying the program.  Get rid of the #int_rda and #int_tbe
 routines until you get the eeprom working reliably.
 Also, your posted code looks like it's a CCS driver, but I don't find any
 such driver in the CCS directories.  I don't find it if I search the net with
 Google.  So I could be wrong, but I think you've created an invention
 and tacked the CCS copyright message on it.
		| tomay3000
				|  Posted: Mon Jul 12, 2010 8:26 am |   |
				|  	  | PCM programmer wrote: |  	  | Post the full part number of the eeprom that you're testing, and post a link to the eeprom data sheet, and post your compiler version.
 Sorry for my previous post
 & for the full part number of my SPI EEPROM is : W25X40A
 & a link to its datasheet is : http://www.winbond.com.tw/NR/rdonlyres/93A5FE5A-EEF2-417B-87A8-CB8144F6120D/0/W25X10A_W25X20A_W25X40A_W25X80A.pdf
 & my compiler version is : 4.106
 & for the W25Xxx.C driver, I crated it using the athor drivers samples.
 & I did this test program test.h:
 & the test.c main program is :
  	  | Code: |  	  | #include "test.h" #include <stdio.h>
 setup_vref(FALSE);
 //TODO: User Code
 putc(getc());
 & I always receive what I sent to the PIC. So it is working
 This is an image of my EEPROM Programmer :
 http://www.wuala.com/tomay3000/Documents/Electronics/EEPROM%20Programmer.JPG
 & the JDM Programmer for the PIC :
 http://www.wuala.com/tomay3000/Documents/Electronics/JDM%20Programmer.JPG
 PIC16F628A
		| tomay3000
				|  Posted: Wed Jul 14, 2010 11:09 am |   |
				| Finally, I found the solution. The problem was in the VCC voltage, so the Winbond SpiFlash supports a range of (2.7 --> 3.6) volts, not 5 volts, so I found that my Winbond W25Xxx SpiFlash is gone  with a 5 volts    & my PIC16F628A is working great. _________________
 PIC16F628A
 | You cannot post new topics in this forum You cannot reply to topics in this forum
