Miguel Martin Guest
| Convert integer to hex |
Posted: Fri Apr 25, 2003 1:48 am |
I response with new post, due the forum reject my reply.
This message is for Jarle.
You can done the task with next code:
first, define next array as global....
char hexchar[2]; //matriz cadena de cálculo de valores binarios de 2 cars. ascii hex
and after, the function atohex(int valor) gives the string you need..
void atohex(int valor){
devuelve el caracter hex del byte pasado como entero de 8 bits en la cadena hexchar
int temp001;
temp001 = valor >> 4;
if (temp001 >= 0 && temp001 < 10){
hexchar[0]= temp001 + '0'; //si es en rango de 0..9
else {
hexchar[0]= temp001 + '7'; //si es en rango de A..F
temp001 = valor & 0x0f;
hexchar[1]= temp001 + '0'; //si es en rango de 0..9
else {
hexchar[1]= temp001 + '7'; //si es en rango de A..F
___________________________
Original Post ID: 13987 |
Bruce R. Knox Guest
| Re: Convert integer to hex |
Posted: Fri Apr 25, 2003 6:30 am |
:=I response with new post, due the forum reject my reply.
:=This message is for Jarle.
:=You can done the task with next code:
:=first, define next array as global....
:=char hexchar[2]; //matriz cadena de cálculo de valores binarios de 2 cars. ascii hex
:=and after, the function atohex(int valor) gives the string you need..
:=void atohex(int valor){
:=devuelve el caracter hex del byte pasado como entero de 8 bits en la cadena hexchar
:= int temp001;
:= temp001 = valor >> 4;
:= if (temp001 >= 0 && temp001 < 10){
:= hexchar[0]= temp001 + '0'; //si es en rango de 0..9
:= break;
:= else {
:= hexchar[0]= temp001 + '7'; //si es en rango de A..F
:= break;
:= temp001 = valor & 0x0f;
:= hexchar[1]= temp001 + '0'; //si es en rango de 0..9
:= break;
:= else {
:= hexchar[1]= temp001 + '7'; //si es en rango de A..F
:= break;
or, you could use
printf("\%c",value);
Bruce
Original Post ID: 13991 |
R.J.Hamlett Guest
Posted: Fri Apr 25, 2003 1:30 pm |
:= int temp001;
:= break;
:= else {
:= break;
:= break;
:= else {
:= break;
I think Jarle, needs to work out what is really wanted...
You cannot send a two character hex value, in one character. I doubt if the system at the other end actually receives hex, so it probably just wants the 'raw' character (not hex at all), in which case simply using the \%c character in the printf statement, or a simple 'putc', is what is needed.
However if the value needs to be sent as hex, then two characters will be needed for each byte, and the \%x syntax is correct (why re-invent the wheel - printf allready has a hex output conversion...).
Original Post ID: 13998 |
Miguel Martin Guest
Posted: Fri Apr 25, 2003 5:00 pm |
:=:=I response with new post, due the forum reject my reply.
:=:=This message is for Jarle.
:=:=You can done the task with next code......:=:=}
:=I think Jarle, needs to work out what is really wanted...
:=You cannot send a two character hex value, in one character. I doubt if the system at the other end actually receives hex, so it probably just wants the 'raw' character (not hex at all), in which case simply using the \%c character in the printf statement, or a simple 'putc', is what is needed.
:=However if the value needs to be sent as hex, then two characters will be needed for each byte, and the \%x syntax is correct (why re-invent the wheel - printf allready has a hex output conversion...).
:=Best Wishes
Hi. In most cases, is necessary to send to RS232 a byte coded in hex form. Not "0xff", par example, to send a 255 value.
I use the routine shown to form a frame in hex buffer, posterior calculation of vertical parity, and send to rs 232.
In earliers version of CCS compiler, (lower than 2.734), the function sprintf() is not implemented, and I developed the routine to form "quasi equal" in buffer the result.
The continued use of the routine is my "vice".
I will try to use sprintf(). Probably, is more efective.
But my program works fine....
regards.
Original Post ID: 14002 |
R.J.Hamlett Guest
Posted: Sun Apr 27, 2003 4:36 am |
:=:=:=I response with new post, due the forum reject my reply.
:=:=:=This message is for Jarle.
:=:=:=You can done the task with next code......:=:=}
:=:=I think Jarle, needs to work out what is really wanted...
:=:=You cannot send a two character hex value, in one character. I doubt if the system at the other end actually receives hex, so it probably just wants the 'raw' character (not hex at all), in which case simply using the \%c character in the printf statement, or a simple 'putc', is what is needed.
:=:=However if the value needs to be sent as hex, then two characters will be needed for each byte, and the \%x syntax is correct (why re-invent the wheel - printf allready has a hex output conversion...).
:=:=Best Wishes
:=Hi. In most cases, is necessary to send to RS232 a byte coded in hex form. Not "0xff", par example, to send a 255 value.
Er. Except the original poster, is complaining that the \%x form generates two bytes. This is inherent in sending the data in hex format...
:=I use the routine shown to form a frame in hex buffer, posterior calculation of vertical parity, and send to rs 232.
:=In earliers version of CCS compiler, (lower than 2.734), the function sprintf() is not implemented, and I developed the routine to form "quasi equal" in buffer the result.
:=The continued use of the routine is my "vice".
:=I will try to use sprintf(). Probably, is more efective.
:=But my program works fine....
It will (inherently), still have to give two characters, and given this was what the poster was complaining about, it seems likely that in fact 'hex' format is not what is required, but just 'raw' data (ie. \%c)....
Hence my comment that Jarle really needs to work out what is needed.
Original Post ID: 14019 |
