kthomas
| Aligning a Function in Memory |
Posted: Thu Jul 08, 2010 11:09 am |
I am trying to use a #org statement to place a function in the last row of program memory. Specifically, I want to make a sleep statement the very last instruction in program memory.
However, the compiler wants to put a RETURN statement at the end of the function (thus making it the last instruction in memory). Is there a way to tell the compiler not to do this? Here is the code I have written and how it is compiled:
| Code: | #ORG (getenv("PROGRAM_MEMORY")-63), (getenv("PROGRAM_MEMORY")-1)
void goToSleep()
#asm
//NOP I want to uncomment this, but the compiler chokes because it injects a RETURN. See below
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
PWRSAV #0
#endasm
Here is the .lst of how it is compiled:
| Code: | void goToSleep()
.................... #asm
.................... //NOP I want to uncomment this, but the compiler chokes because it injects a RETURN. See below
.................... NOP
AFC0: NOP
AFC2: NOP
AFC4: NOP
AFC6: NOP
AFC8: NOP
AFCA: NOP
AFCC: NOP
AFCE: NOP
AFD0: NOP
AFD2: NOP
AFD4: NOP
AFD6: NOP
AFD8: NOP
AFDA: NOP
AFDC: NOP
AFDE: NOP
AFE0: NOP
AFE2: NOP
AFE4: NOP
AFE6: NOP
AFE8: NOP
AFEA: NOP
AFEC: NOP
AFEE: NOP
AFF0: NOP
AFF2: NOP
AFF4: NOP
AFF6: NOP
AFF8: NOP
AFFA: NOP
.................... PWRSAV #0
AFFC: PWRSAV #0
.................... #endasm
AFFE: RETURN // I want the PWRSAV instruction here! |
I am using v4.099 on a dsPIC30F5011. |
Posted: Thu Jul 08, 2010 1:29 pm |
I don't have your compiler, so I tested this for an 18F452.
I put a Branch statement at the end of the routine, so it will jump
over the RETLW instruction and jump to a SLEEP instruction that
I've inserted at the end of program memory with an #org statement.
I don't guarantee this is the best way to do it. It's one way that I
quickly thought of.
#include <18F452.h>
#inline
void goToSleep()
#asm
//NOP
//NOP
//NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP // 10
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP // 20
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP // 29
bra 0x7FFE
#endasm
#rom 0x7FFE = {0x0003} // Sleep Opcode for 18F452
kthomas
Posted: Thu Jul 08, 2010 1:36 pm |
Thanks. That got me thinking of another solution. Just use a #rom to fill the entire area with NOPs and stick the sleep opcode at the end. Basically what you're doing without the need of writing a function --
| Code: | | #rom 0x17FC0 = {0,0,0...until last instruction...,0xFE4000} |
Where 0xFE4000 is the PWRSAV #0 instruction |
Posted: Thu Jul 08, 2010 1:51 pm |
| Quote: |
That would work too. I wasn't sure exactly what you were trying to do,
so that's why I tried to maintain as much of your function as possible. |
kthomas
Posted: Thu Jul 08, 2010 1:57 pm |
| You got me going down the right path, thanks. |
