I2C master - slave communication
bungee-
PostPosted: Sun Jul 04, 2010 1:07 pm     Reply with quote
Hi all!
I'm trying to communicating between two PIC's with I2C protocol and I'm having troubles...
Circuit is simple as it is could be. Two PIC16F886 each have LCD connected on portB, SCL and SDA are connected together and 4k7 pullup resistors are on them. This is it. Hardware is actually put together on protoboard.
Code for slave is taken out from EX code and modified a little. Everything stops at master i2c_stop() command at the end of code. If I disconnect slave then master go over that point. I was looking what happens with oscilloscope and SDA line stays low at that point of program.
Here is code
MASTER:
#include <16F886.h>
#FUSES NOWDT,INTRC_IO,PUT,NOMCLR,NOPROTECT,NOCPD,NOBROWNOUT,NOIESO
#FUSES NOFCMEN,NOLVP,NODEBUG,NOWRT,BORV40
#use delay(clock=8000000)
#define I2C_SCL   PIN_C3
#define I2C_SDA   PIN_C4
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3,force_hw)
#include "flex_lcd.c"
void setup()
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_comparator(false);
   setup_oscillator(OSC_8MHZ);
   lcd_init();
int8 data,t;
   setup();
   lcd_putc("Start...  \n");
   while (1)
   i2c_start();
   i2c_write(0xA0);
   i2c_write(0x00);
   i2c_write('A');
   i2c_stop();
   delay_ms(1);
   i2c_start();
   i2c_write(0xA0);
   i2c_write(0x00);
   i2c_start();
   i2c_write(0xA1);
   data=i2c_read();
   i2c_stop(); //<--- IT STOPS HERE!!!
   printf(lcd_putc," Read: %u \n",data);
SLAVE:
#include <16F886.h>
#use i2c(Slave,Slow,sda=PIN_C4,scl=PIN_C3,force_hw,address=0xA0)
byte address, buffer[0x10];
BYTE incoming, state, ping;
#int_SSP
void  SSP_isr(void)
state = i2c_isr_state();
   if(state <= 0x80)                     //Master is sending data
      incoming = i2c_read();
      if(state == 1)                     //First received byte is address
         address = incoming;
      if(state == 2)                     //Second received byte is data
         buffer[address] = incoming;
   if(state == 0x80)                     //Master is requesting data
      i2c_write(buffer[address]);
      ping=1;
void setup()
   setup_adc(ADC_OFF);
   enable_interrupts(INT_SSP);
   lcd_init();
   ping=0;
   int t;
   setup();
   Printf(lcd_putc,"Ready ...\n");
      if (ping==1)
         lcd_putc('.');
         ping=0;
Please can somebody give me a fresh perspective, I'm stuck in a loop Rolling Eyes thank's!
PostPosted: Sun Jul 04, 2010 1:26 pm     Reply with quote
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_start();
i2c_write(0xA1);
data=i2c_read();
You have to do a NACK on the last read. This is in the i2c spec.
Do this by giving the i2c_read() function a 0x00 parameter.
bungee-
PostPosted: Sun Jul 04, 2010 1:39 pm     Reply with quote
I bow to the master!
Thank you ... as I said I was caught in a loop.
Do you have a good title to read about I2C spec?
PostPosted: Sun Jul 04, 2010 1:51 pm     Reply with quote
Here's the i2c spec.
http://www.nxp.com/acrobat_download2/literature/9398/39340011.pdf
The part about the Master doing a NACK on the last byte to be read
is in the last paragraph on page 10.
I just noticed that Philips came up with a more easy-to-read version
of the i2c spec:
http://www.nxp.com/documents/user_manual/UM10204.pdf
In that one, the NACK is explained in item #5 on page 10.
bungee-
PostPosted: Sun Jul 04, 2010 4:22 pm     Reply with quote
Thank you for that and rapid response! Cool
