nemero16
| Problem with LCD NOKIA 6610 and 16F87X |
Posted: Mon Jul 05, 2010 9:14 am |
hi I'm working with a Nokia 128x128 LCD and a PIC16F876A but I do not know if the screen controller is EPSON or PHILIPS ... this is the sample code I'm using but when I turn on the circuit, the screen lights (LEDs light), but remains the panel LCD black ... what is the problem? here's the code:
| Code: | //// Russell Evolutions Inc.
//// Nokia 6100 LCD with Epson S1D15G10 Controller
//// sample initialization program for PIC16LF872 in CCS C 3-14-07
//// Based on Spark Fun Electronics Code by Owen Osborn 1-22-05
//// with thanks to David Carne of SFE for DISCTL help
//// and user 'Ttelmah' from CCS C forum for SSPEN bit idea for 9-bit hardware SPI
//// You are free to use this code for any purpose.
//// START OF HEADER FILE ////
#include <16F876.h>
#device adc=8
#FUSES XT //Crystal Osc (<= 4mhz)
#FUSES PUT //Power Up Timer
#FUSES NOBROWNOUT //Don't Reset when brownout detected
#define LCD_RESET PIN_C6
#define LCD_CS PIN_B0
#define SPI_CLK PIN_B1
#define SPI_DI PIN_C4 //unused
#define SPI_DO PIN_C7
#bit SSPEN = 0x14.5 // bit to turn on/off hardware SPI
// Epson S1D15G10 Command Set
#define DISON 0xaf
#define DISOFF 0xae
#define DISNOR 0xa6
#define DISINV 0xa7
#define SLPIN 0x95
#define SLPOUT 0x94
#define COMSCN 0xbb
#define DISCTL 0xca
#define PASET 0x75
#define CASET 0x15
#define DATCTL 0xbc
#define RGBSET8 0xce
#define RAMWR 0x5c
#define RAMRD 0x5d
#define PTLIN 0xa8
#define PTLOUT 0xa9
#define RMWIN 0xe0
#define RMWOUT 0xee
#define ASCSET 0xaa
#define SCSTART 0xab
#define OSCON 0xd1
#define OSCOFF 0xd2
#define PWRCTR 0x20
#define VOLCTR 0x81
#define VOLUP 0xd6
#define VOLDOWN 0xd7
#define TMPGRD 0x82
#define EPCTIN 0xcd
#define EPCOUT 0xcc
#define EPMWR 0xfc
#define EPMRD 0xfd
#define EPSRRD1 0x7c
#define EPSRRD2 0x7d
#define NOP 0x25
#define ENDPAGE 132
#define ENDCOL 130
//// START OF MAIN .C SOURCE FILE ////
//#include "<path to .h file cut from above>"
#use fast_io(C)
void pset(unsigned char color, unsigned char x, unsigned char y);
void spi_command(int);
void spi_data(int);
int16 i;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED, 0, 1);
set_tris_c(0x00); // all outputs, can change to mask only hardware SPI bits if needed
// reset display
output_low (SPI_CLK);
output_low (SPI_DO);
output_high (LCD_CS);
output_low (LCD_RESET);
output_high (LCD_RESET);
//init'd, now drop CS to send commands/data and raise when finished
spi_command(DISCTL); // display control
spi_data(0x0C); // 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
spi_data(0x20); // 32 = (128/4)-1 (round up) number of display lines for scanning
spi_data(0x0C); // 12 = 1100 - number of lines to be inversely highlighted
spi_data(0x00);
spi_command(COMSCN); // common scanning direction
spi_data(0x01);
// 0 0 0 = 1 -> 80 81 -> 160
// 0 0 1 = 1 -> 80 81 <- 160
// 0 1 0 = 1 <- 80 81 -> 160
// 0 1 1 = 1 <- 80 81 <- 160
spi_command(OSCON); // internal oscialltor ON
spi_command(SLPOUT); // sleep out
spi_command(VOLCTR); // electronic volume, this is the contrast/brightness
spi_data(0x23); // volume (contrast) setting - fine tuning
spi_data(0x03); // internal resistor ratio - coarse adjustment
spi_command(PWRCTR); // power ctrl
spi_data(0x0f); //everything on, no external reference resistors
spi_command(DISINV); // invert display mode
spi_command(DATCTL); // data control
spi_data(0x00); // normal display of page/column address, page scan direction
spi_data(0x00); // normal RGB arrangement
spi_data(0x01); // 8-bit grayscale
spi_command(RGBSET8); // setup 8-bit color lookup table [RRRGGGBB]
//RED
spi_data(0);
spi_data(2);
spi_data(4);
spi_data(6);
spi_data(8);
spi_data(10);
spi_data(12);
spi_data(15);
// GREEN
spi_data(0);
spi_data(2);
spi_data(4);
spi_data(6);
spi_data(8);
spi_data(10);
spi_data(12);
spi_data(15);
//BLUE
spi_data(0);
spi_data(4);
spi_data(9);
spi_data(15);
spi_command(NOP); // nop
pset(0b11100000, 0, 0); // red pixel top left (also sets start of bulk write, see pset routine)
for (i = 1; i <= 16900; i++) { // 130x130 = 16900
spi_data(0b11100000); // fill screen red
spi_command(DISON); // display on
while (1) { // main program loop. just blinks A0 to show chip is running
output_toggle(PIN_A0);
void pset(unsigned char color, unsigned char x, unsigned char y){
// sets the starting page(row) and column (x & y) coordinates in ram,
// then writes the colour to display memory. The ending x & y are left
// maxed out so one can continue sending colour data bytes to the 'open'
// RAMWR command to fill further memory. issuing any other command
// finishes RAMWR.
x += 2; // for some reason starts at 2
spi_command(PASET); // page start/end ram
spi_data(x);
spi_data(ENDPAGE);
spi_command(CASET); // column start/end ram
spi_data(y);
spi_data(ENDCOL);
spi_command(RAMWR); // write
spi_data(color);
void spi_command(int dat){
output_low(LCD_CS); // enable chip
SSPEN = 0; // shut off hardware SPI allowing direct access to SPI in/out pins
output_low (SPI_DO); // output low on data out (9th bit low = command)
output_high (SPI_CLK);
delay_cycles(1); // send clock pulse
SSPEN=1; // turn hardware SPI back on
spi_write(dat); // make PIC do the work for the command byte
output_high(LCD_CS); // disable
void spi_data(int dat){
SSPEN = 0; // turn off hardware SPI allowing us direct access to SPI in/out pins
output_high (SPI_DO); // output high on data out (9th bit high = data)
spi_write(dat); // make PIC do the work for the data byte
Posted: Mon Jul 05, 2010 12:27 pm |
You got that code from this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=37345
But that code is buggy. It's newbie code.
Picoholic provided a link to a Zip file of Nokia code on the Sparkfun
website (nokial6100_ccs_c.zip). Look for the link on that thread.
The Sparkfun code uses the hardware SPI pins, C3, C4, and C5.
The newbie that you copied has screwed up all those pins and
put them on Port D. There's no hardware SPI on Port D.
But then, you have continued this error by moving the pins
to a bunch of other non-hardware SPI pins.
| Quote: |
My advice is, go back to the original Sparkfun code. I don't know if it
works, but at least it's using the real hardware pins. |
nemero16
Posted: Mon Jul 05, 2010 1:47 pm |
ok I changed the ports and changed the code like this:
| Code: | //// Marcus Russell
#include <16F876.h>
#device adc=8
#define LCD_RESET PIN_C0
#define LCD_CS PIN_C1
#define SPI_CLK PIN_C3
#define SPI_DO PIN_C5
#define DISON 0xaf
#define DISOFF 0xae
#define DISNOR 0xa6
#define DISINV 0xa7
#define SLPIN 0x95
#define SLPOUT 0x94
#define COMSCN 0xbb
#define DISCTL 0xca
#define PASET 0x75
#define CASET 0x15
#define DATCTL 0xbc
#define RAMWR 0x5c
#define RAMRD 0x5d
#define PTLIN 0xa8
#define PTLOUT 0xa9
#define RMWIN 0xe0
#define RMWOUT 0xee
#define ASCSET 0xaa
#define OSCON 0xd1
#define OSCOFF 0xd2
#define PWRCTR 0x20
#define VOLCTR 0x81
#define VOLUP 0xd6
#define TMPGRD 0x82
#define EPCTIN 0xcd
#define EPCOUT 0xcc
#define EPMWR 0xfc
#define EPMRD 0xfd
#define NOP 0x25
#define ENDPAGE 132
#define ENDCOL 130
#use fast_io(C)
void spi_data(int);
int16 i;
setup_adc(ADC_OFF);
// reset display
spi_data(0x00);
spi_data(0x01);
//RED
spi_data(0);
spi_data(2);
spi_data(4);
spi_data(6);
spi_data(8);
spi_data(10);
spi_data(12);
spi_data(15);
// GREEN
spi_data(0);
spi_data(2);
spi_data(4);
spi_data(6);
spi_data(8);
spi_data(10);
spi_data(12);
spi_data(15);
//BLUE
spi_data(0);
spi_data(4);
spi_data(9);
spi_data(15);
// finishes RAMWR.
spi_data(x);
spi_data(ENDPAGE);
spi_data(y);
spi_data(ENDCOL);
spi_data(color);
but the result is always the same ... maybe a Philips controller? Where can I find some examples ready just as a test for the Philips controller? |
