8bit data to uart
jacqueskleynhans
8bit data to uart
PostPosted: Fri Jun 11, 2010 8:42 am     Reply with quote
HI Guys I need to write 8 bits of data to the UART, data is received as input on the pic from an FPGA. I can set the data rate to accommodate the pic.
Can any suggest something that can aid me.
Thx
"THE ONLY EASY DAY WAS YESTERDAY"
PostPosted: Fri Jun 11, 2010 9:57 am     Reply with quote
You just send it....
If the PIC UART is set to 8bit mode, it'll accept 8bit data. putc, printf, all output 8bit data.
If you look at 'ex_temp.c', this sends the temperature from a sensor, over the RS232 as ASCII text. If you modify the printf lne to:
printf("%c\",value);
//or
putc(value);
It'll send the reading as successive 8bit bytes instead (without the line feed and carriage return, since these will now be acceptable 'values' for the transmission.
jacqueskleynhans
PostPosted: Fri Jun 11, 2010 9:59 am     Reply with quote
HI I wrote this quick to test but I'm getting jibberish on the output
#include <16F877A.H>
#include <hardware.h>
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#use FAST_IO(D)
#define ALL_IN 0xff
int8 value;
set_tris_d(ALL_IN);
value = (PORTD);
printf("PortD = %c \n\r", value);
ok I changed the the %c to an %u for unsigned and it worked Smile
PostPosted: Fri Jun 11, 2010 2:28 pm     Reply with quote
You would get 'gibberish'.
You were asking about sending '8bit values'. This means sending bytes, that hold all possible numeric values from 0 to 255. If displayed as text, these would be 'gibberish'. However store the output, and display the stored values in hex, and the numbers are the numbers being sent, as required.
These can be directly latched by a FPGA, and are the numbers wanted.
Changing to %u, makes the code instead send _multiple bytes_ for each value, in ASCII text. Nice and easy for a human to read, but no use into an FPGA. You would need to generate the hardware in the FPGA, to recognise the ASCII values, decode them back to binary, identify the end of number 'marker' character, and then re-assemble the result. Latching the values with an FPGA, in binary mode (the gibberish), could be done in a few dozen gates. Taking the values in ASCII, and regenerating the binary value, would require a few hundred gates instead.....
