daniel123 Guest
| 16F684 pwm motor control |
Posted: Wed Jul 29, 2009 7:19 am |
I'm using the pwm module of pic16f684 to control the speed of a DC motor. The only problem is when the duty cycle is zero the motor is still running. Could someone help me.
thank you |
Posted: Wed Jul 29, 2009 7:38 am |
Start by disconnecting the motor, set a duty cycle of zero, and measure what is coming out of the PWM pin. If you have a scope, use this, otherwise, wire up a LED, with a current limiting resistor, and attach this to the pin. Is it off?. If it is, then the problem is in the hardware you are using to drive the motor. Perhaps the transistor is not quite switching off?. If it is on, then simplify the code down to just a routine to setup the timer, and setting the duty cycle to zero. Does this solve the problem?. If not, then the 'odds' are that possibly the PWM output pin itself has been damaged. Classic for doing this, is using a transistor to drive a motor/inductor, without a 'trap' diode across it, or some other circuit to catch flyback. Without this, when the drive switches off, the inductance in the coil (and the generator effect for a motor), can generate a massive voltage, having nowhere to 'go', and eventually finds a route, from the collector to the base of the transistor, then from this into the output of the PIC....
delifadzli
Posted: Sun Jun 06, 2010 12:43 pm |
| Code: | #include <16F877A.h>
#device ADC=10
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
#use Delay(clock=20000000)
#include "C:\Users\deli\Desktop\satu\brum\Flexlcd2.c"
#define medium 500L
#define slow 100L
#define fast 700L
//#define medium 125L
//#define slow 63L
//#define fast 240L
int16 temp_adc;
float temp;
int16 pwm_duty;
setup_adc(ADC_CLOCK_DIV_8);
setup_adc_ports(PIN_A1);
set_adc_channel(1); //read analog input from channel 1
output_low(PIN_C2); // Set CCP1 output low
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_4, 249, 1); // 5khz
set_pwm1_duty(medium); // Set for 50% duty cycle
lcd_init();
lcd_putc("\fsuhu leni:\n");
temp_adc = read_adc();
temp = 5.00*temp_adc*100.00/1023.00;
lcd_gotoxy(1,2);
printf(lcd_putc,"%f",temp);
delay_ms(3000);
if ((temp_adc < 58) && (input(PIN_B7)==1))
temp_adc = slow;
else if ( (temp_adc >= 58) && (temp_adc < 70) && (input(PIN_B7)==1))
temp_adc = medium;
else if ((temp_adc >= 70) && (input(PIN_B7)==1))
temp_adc = fast;
temp_adc = 0;
set_pwm1_duty(temp_adc); //Change duty cycle and adjust
Isn't in this code...I can produce zero speed--means motor turn off...I also had the same problem....other routine...seems to be ok, just for the turning off the motor- it cause the motor to run at full speed...?? why
input pinb7 just additional pin that i planned to use for another sensor..but in this time i just use a wire.... |
