12c508a problem
Diego Guzman
12c508a problem
PostPosted: Wed Apr 23, 2003 9:39 am     Reply with quote
Hi, im working for first time with pic12c508a, and i have a problem setting the internal clock, it doesnt work, i put the direcitives of __config _IntRC_OSC and then put 0xff in the oscal register to have the highest frequency, and doesnt work.
I need to generate a square singal of 700khz, so i need help to setup the internal clock at 4Mhz.
I read that the directive #rom 0x000 = {0x0025} works, thats ok??
Diego
Original Post ID: 13944
Re: 12c508a problem
PostPosted: Wed Apr 23, 2003 11:45 am     Reply with quote
:=Hi, im working for first time with pic12c508a, and i have a problem setting the internal clock, it doesnt work, i put the direcitives of __config _IntRC_OSC and then put 0xff in the oscal register to have the highest frequency, and doesnt work.
CCS does not use the __config directive. CCS uses the #fuses
directive. This is in the manual.
See this example program, which shows how to use the #fuses
statement:
<a href="http://www.cc.puv.fi/~t0101190/projekti/source/Examples/ex_8pin.c" TARGET="_blank">http://www.cc.puv.fi/~t0101190/projekti/source/Examples/ex_8pin.c</a>
Original Post ID: 13947
Diego Guzman
Re: 12c508a problem
PostPosted: Thu Apr 24, 2003 9:30 am     Reply with quote
I'm confused because i´m working with both assembler and ccs, because both of them doesnt work. In the ccs using the #fuse directive, and define the I/O lines, using the next code:
#include <12C508A.h>
#fuses NOWDT, NOPROTECT, INTRC, MCLR
#use fast_io(B)
#byte portb = 0x06
#bit rec = 0x06.4
#bit tri = 0x06.0
#bit emi = 0x06.2
#use delay(clock = 4000000)
#rom 0x000 = {0x0025} ; this directive i use because i read
with this the internal rc works but
it doesnt
inicializar (){
portb = 0x00;
set_tris_b(0b00011000);
inicializar();
portb = 0x00;
while (TRUE){
if(rec==0){
tri = 0;
emi = 1;
delay_ms(0.7);
emi = 0;
delay_ms(0.7);
else tri = 1;
i dont know what is wrong here, could you help me..
Original Post ID: 13974
R.J.Hamlett
Re: 12c508a problem
PostPosted: Thu Apr 24, 2003 10:50 am     Reply with quote
:=I'm confused because i´m working with both assembler and ccs, because both of them doesnt work. In the ccs using the #fuse directive, and define the I/O lines, using the next code:
:=#include <12C508A.h>
:=#fuses NOWDT, NOPROTECT, INTRC, MCLR
With MCLR selected, you must ensure that pin 4 has a pull-up. Is this true?.
:=#use fast_io(B)
:=#byte portb = 0x06
:=#bit rec = 0x06.4
:=#bit tri = 0x06.0
:=#bit emi = 0x06.2
:=#use delay(clock = 4000000)
:=#rom 0x000 = {0x0025} ; this directive i use because i read
:= with this the internal rc works but
:= it doesnt
You do not need this. If you select the RC oscillator, the compiler automatically inserts a MOVWF 05 instruction at the start of memory.
:=inicializar (){
:= portb = 0x00;
:= set_tris_b(0b00011000);
:=void main() {
:= inicializar();
:= portb = 0x00;
:= while (TRUE){
:= if(rec==0){
:= tri = 0;
:= emi = 1;
:= delay_ms(0.7);
You cannot have floating point delays. If you want a 0.7mSec delay, use delay_us(700);
:= emi = 0;
:= delay_ms(0.7);
:= else tri = 1;
:=i dont know what is wrong here, could you help me..
I suspect the main fault, is the use of a floating point value on the delay.
Original Post ID: 13977
Diego Guzman
Re: 12c508a problem
PostPosted: Sat Apr 26, 2003 10:22 am     Reply with quote
Thank you R.J.Hamlett, i'm gone a try your tips, i only need to buy more 12c508a
Original Post ID: 14011
Felix Althaus
Re: 12c508a problem
PostPosted: Sat Apr 26, 2003 12:50 pm     Reply with quote
:=Thank you R.J.Hamlett, i'm gone a try your tips, i only need to buy more 12c508a
What about using a -JW part with eprom and window to erase this with UV light (if they exist for 12c508)?
So you only need one part for experimenting (ok, it will cost more)
mfg
Felix
Original Post ID: 14013
