setting adc vref
suardi
setting adc vref
PostPosted: Tue May 04, 2010 9:45 pm     Reply with quote
Compiler version 4.057
I'm trying to configure vref for the adc but the compiler give me error.
The error is: setup_adc_ports(RA0_RA1_RA3_ANALOG);
That line I took from the CCS help.
Any idea how to configure vref? I don't want to use the 5V vref cause
my input volt range from 0 to 2V.
#include <18F4550.h>
#DEVICE ADC=8
#include <math.h>
//configure a 20MHz crystal to operate at 48MHz
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=19200, xmit=PIN_B6, rcv=PIN_B7,errors,INVERT)
unsigned int8 i, value, min, max;
printf("Sampling:");                      // Printf function included in RS232 library
setup_adc_ports( RA0_RA1_RA3_ANALOG );
setup_adc(ADC_CLOCK_INTERNAL);            // Built-in A/D setup function
set_adc_channel(0);                       // Built-in A/D setup function
do {
   min=255;
   max=0;
   for(i=0; i<=30; ++i) {
      delay_ms(100);                      // Built-in delay function
      value = read_adc();                 // Built-in A/D read function
      if(value<min)
         min=value;
      if(value>max)
         max=value;
   printf("\r\nMin: %2X  Max: %2X\n\r",min,max);
} while (TRUE);
PostPosted: Wed May 05, 2010 12:37 am     Reply with quote
The parameters used for that function can vary, according to the PIC
family. The one above is for the 16F877. Look in the 18F4550.h file
to see the available parameters for that PIC. There is a list of them
in the file (near the end) in this section:
// Constants used in SETUP_ADC_PORTS() are:
Here's the file location on your PC:
c:\program files\picc\devices\18f4550.h
suardi
PostPosted: Wed May 05, 2010 1:47 am     Reply with quote
thanks PCM, i finally get it worked.
this is from the .h file :
// The following may be OR'ed in with the above using |
#define VSS_VDD 0x00 // Range 0-Vdd
#define VREF_VREF 0x30 // Range VrefL-VrefH
#define VREF_VDD 0x20 // Range VrefL-Vdd
#define VSS_VREF 0x10 // Range 0-VrefH
and this is my setup(vref is connected to pin RA3):
setup_adc_ports(AN0|VSS_VREF);
thanks again.
