FLEX_glcd driver
ÜnLoCo
FLEX_glcd driver
PostPosted: Tue May 04, 2010 10:46 am     Reply with quote
Hello I have got a testing platform with a glcd (240*128).
I'm trying to make a flex_glcd driver in order to make it work.
This is the original code
http://www.ccsinfo.com/forum/viewtopic.php?t=31255
and this is my code but it still don't work. That's why I need some help with it !
////    T6963C.c     -      T6963C driver                            ////
////   Not for comercial Use                                         ////
////      Driver by treitmey Graphic functions and Resolution Select ////
////                                    by endSly (endsly@gmail.com) ////
//// This file contains drivers for using a Tosiba T6963C controller ////
//// in parallel/8080(intel) mode.  The T6963C is 240 pixels across  ////
////  and 64 pixels down. The driver treats the upper left pixel 0,0 ////
////  Connections are as follows:                                    ////
////  /WR - - C5                                                     ////
////  /RD - - D4                                                     ////
////  C//D- - C6                                                     ////
////  /RST- - VCC                                                     ////
////  DATA0-7 PORTD0-7                                               ////
////  LCD's FS is tied low (FS = 0 is 8x8 font)                      ////
// 240 x 64 in the 8x8 font mode means that 30 characters across by
// 8 rows of characters may be displayed
#define set_tris_lcd(x) set_tris_b(x)
#define LCDColorBlack 0b1
#define LCDColorWhite 0b0
//TRIS DataBus=x,  note:control bus (PORTC) always outputs
unsigned int16 TextHome = 0x0F00;//0x0780;
const int8  TextArea = 0x001E; // how many bytes before a new line
const int16 GraphicsHome = 0x0000;
const int8  GraphicsArea = 0x001E; // how many bytes before a new line
const int8 AutoModeWrite = 0xB0;
const int8 AutoModeRead  = 0xB1;
const int8 AutoModeReset = 0xB2;
const int8 LCDModeSet  = 0x80;   // send this OR'd with the following
const int8 LCDMode_OR  = 0b0000;
const int8 LCDMode_XOR = 0b0001;
const int8 LCDMode_AND = 0b0010;
const int8 LCDMode_TA  = 0b0100; // TEXT ATTRIBUTE mode.
const int8 LCDMode_RAM = 0b1000; // 1=CG RAM, 0=internal CG ROM
const int8 LCDSetCursorPtr  = 0x21;  // cursor address
const int8 LCDSetCursorSize = 0xA0;  // 1 line cursor
const int8 LCDDispMode = 0x90;   // send this OR'd with the following
const int8 LCDDisp_BLK = 0b0001;
const int8 LCDDisp_CUR = 0b0010;
const int8 LCDDisp_TXT = 0b0100;
const int8 LCDDisp_GRH = 0b1000;
const int8 LCDBitSet   = 0xF8;
const int8 LCDBitReset = 0xF0;
const int8 LCDBit0 = 0b000;
const int8 LCDBit1 = 0b001;
const int8 LCDBit2 = 0b010;
const int8 LCDBit3 = 0b011;
const int8 LCDBit4 = 0b100;
const int8 LCDBit5 = 0b101;
const int8 LCDBit6 = 0b110;
const int8 LCDBit7 = 0b111;
const int8 LCDSetPtr = 0xE0;
 #byte LCD = 0xf82    // portC address on 18F452
int   glcd_ReadByte(void);
void  glcd_WriteByte(int1 _cd, int data);
void  glcd_WriteByteAuto(int data);
void  glcd_WriteCmd2(int16 data, int cmd);
void  glcd_WriteCmd1(int data, int cmd);
void  glcd_gotoxy(int x, int y, int1 text);
#inline
void glcd_init(unsigned int16 res_x, unsigned int16 res_y) {
  int16 counter;
  TextHome = (res_x/8)*res_y; //0x0F00;//0x0780;
  set_tris_c(0x00);  // graphic lcd control lines all output
  set_tris_lcd(0xff);   //TRIS DATA bus,note:control bus always outputs
  output_bit(PIN_C5 , 1);      // INITIAL STATES OF CONTROL PINS
  output_bit(PIN_C6,1);      //
  output_bit(PIN_D4,1);         // command
  output_bit(PIN_C7,0);  // perform a reset
  delay_us(10);      // delay for a reset
  output_bit(PIN_C7,1);  // run
  // Set up the graphics and text areas
  glcd_WriteCmd2(TextHome, 0x40);
  glcd_WriteCmd2(TextArea, 0x41);
  glcd_WriteCmd2(GraphicsHome, 0x42);
  glcd_WriteCmd2(GraphicsArea, 0x43);
  // set address to 0
  glcd_WriteCmd2(0x0000, 0x24);
  // Clear all RAM of LCD (8k)
  glcd_WriteByte(1, AutoModeWrite);
  for (counter = 0; counter < 0x1fff; counter++)
    glcd_WriteByteAuto(0);    // fill everything with zeros
  glcd_WriteByte(1, AutoModeReset);
    int status = 0, temp = 0;
    set_tris_lcd(0xff);
    output_bit(PIN_C5,1);
    output_bit(PIN_C6, 1);
    output_bit(PIN_D4,1);//defaults
    while (status != 0x03) {  // is LCD busy?
      output_bit(PIN_C6, 0);
       temp = INPUT_B();
       status = temp & 0x03;
    set_tris_lcd(0x00);    // All outputs
    output_bit(PIN_D4 , _cd);           // Command/Data bar
    output_bit(PIN_C6,1);         // not read
    output_bit(PIN_C5,0);         // write
    output_bit(PIN_C5,1);         // release
   int status = 0, temp = 0; // status bits ARE DIFFERENT BITS THAN NORMAL
   set_tris_lcd(0xff);
   output_bit(PIN_D4,1); // defaults
   while (status != 0x08) {  // is LCD busy?
     output_bit(PIN_C6,0);
     temp = INPUT_B();
     status = temp & 0x08;
   output_bit(PIN_D4,0);             // This is always data, PIN_D4=0
   output_b(data);         // Put data on data bus
  glcd_WriteByte(0, data);
  glcd_WriteByte(1, cmd);
  glcd_WriteByte(0, data & 0xff);
  glcd_WriteByte(0, data>>8);
  int data = 0, status = 0, temp = 0;
  set_tris_lcd(0xff);
  #asm nop #endasm
    temp = INPUT_B();
  output_bit(PIN_D4,0);          // Command/Data bar
  output_bit(PIN_C6,0);        // read
  #asm nop #endasm    // THIS PAUSE IS VERY NESSESARY !!!//
  output_b(data);
  return INPUT_B();        // Return the read data
void glcd_putc(char c) {
   glcd_WriteCmd1(c - 0x20, 0xc0);
void glcd_gotoxy(int x, int y, int1 text) { // sets memory location to screen location x, y
   // location 1,1 is upper left corner;  text = 1 (text area), text = 0 (graphics area)
   int16 location, home;
   int line;
   if (!text) {
      home = GraphicsHome;
      line = GraphicsArea;
   } else {
      home = TextHome;
      line = TextArea;
   location = home + (((int16)y) * line) + x;
   glcd_WriteCmd2(location, 0x24);
// Purpose:       Clears LCD RAM
void glcd_clr(int16 location,int16 size)
  ////fprintf(DEBUG,"loc=%lu  size=%lu\n\r",location,size);
  // look very simular to the init,... doesn't it. : )
  glcd_WriteCmd2(location,LCDSetPtr);
  glcd_WriteCmd1(1,AutoModeWrite);
  for (;size;size--)
    glcd_WriteByteAuto(0x00);//clear ram
  glcd_WriteCmd1(1,AutoModeReset);
// Graphics Controller by endSly (c)2007
//    endSly@gmail.com
//       Not for comercial use
unsigned int8 i;  //General Purpouse variable
// glcd_pixel(x,y,c) sets pixel x,y with c color
void glcd_pixel(unsigned int8 x, unsigned int8 y, int1 c){
   unsigned int8 x_H;
   unsigned int8 x_L=0;
   x_H = (x / 8);
   x_L = 7 - (x - 8*x_H);
   glcd_gotoxy(x_H,y,0);    //Bug fixed, thanks to etiedon
   if(c){
      glcd_WriteCmd1(1,(LCDBitSet|x_L));
   } else {
      glcd_WriteCmd1(1,(LCDBitReset|x_L));
// glcd_pixel8(x,y,px8) sets 8 pixels in line.
void glcd_pixel8(unsigned int8 x, unsigned int8 y, int8 pixel8){
   unsigned int8 x_H;
   x_H = (x / 8);
   glcd_gotoxy(x_H+1,y,0);
   glcd_WriteCmd1(pixel8,0xc0);
// glcd_line(x0,y0, x1,y1, c) puts line from (x0, y0) to (x1, y1) with c color
#separate
void glcd_line(signed int16 x0, signed int16 y0,
               signed int16 x1, signed int16 y1 , int1 c){
   int16 x;
   int16 y;
   unsigned int16 n;
   int1 m_case;
   x=abs(x1-x0);
   y=abs(y1-y0);
   if (y > x){
      n=(y1-y0);
      m_case=1;
   } else {
      n=(x1-x0);
      m_case=0;
   for(i=0 ; i<=n ; i++){
      if (m_case){
         y=i + y0;
         x=(y*(x1-x0))/(y1-y0) + x0;
      } else {
         x=i + x0;
         y=(x*(y1-y0))/(x1-x0) + y0;
      glcd_pixel(x, y,c);
// glcd_square(x0,y0,x1,y1, c) sets square
void glcd_square( unsigned int8 x0, unsigned int8 y0,
                  unsigned int8 x1, unsigned int8 y1 , int1 c){
   glcd_line(x0,y0, x1,y0, c);
   glcd_line(x1,y0, x1,y1, c);
   glcd_line(x0,y1, x1,y1, c);
   glcd_line(x0,y0, x0,y1, c);
// glcd_box(x0,y0,x1,y1, c)
void glcd_box( unsigned int8 x0, unsigned int8 y0,
   unsigned int8 x;
   unsigned int8 y;
   for(y=y0; y<=y1;y++){
      for(x=x0; x<=x1;x++){
         if((!(x%8)) && ((x1-x)>8)){
            glcd_pixel8(x,y,0xFF*c);  //Same time to write 8 pixel
            x +=7 ;
         } else {
            glcd_pixel(x,y,c);
//glcd_image8 (*Pic, x, y, size_x, size_y)
void glcd_image8(int8 *pic_px, unsigned int8 x, unsigned int8 y,
                 unsigned int8 size_x, unsigned int8 size_y){
   unsigned int8 px_y;
   unsigned int8 px_x;
   unsigned int8 px=0;
   for(px_y=y; px_y<(y+size_y); px_y++){
      for(px_x=x; px_x<(x+size_x); px_x+=8){
         glcd_pixel8(px_x, px_y, *(pic_px+px));
         px+=1;
#use fast_io(D)
you usually find some useful or funny stuff here don't you !
PostPosted: Tue May 04, 2010 10:51 am     Reply with quote
How can this be a flex driver when it has embedded hard-coded pins in
it ?
The CCS glcd.c driver is a flex driver. Look at it for an example of
how to write a driver:
c:\program files\picc\drivers\glcd.c
treitmey
PostPosted: Tue May 04, 2010 5:00 pm     Reply with quote
hint:
you seem to be using a define of settris_lcd that is a define for port b
but then in the code I don't see any use of port b.
